Question about Reliance Natural Gas Water Heater Control
Blue light flashing three times
No how water, blue light flashing. I reset by unplugging it. Now the blue light flashes three times at regular intervals??
Tonight I noticed a blue light flashing on the top of my Stiebel Eltron tankless water heater. What does that mean?
Go to the website and find the manual from your heater. In the Troubleshooting section, it tells you what the sequence of the three lights is. This is a similar model.
operation and installation - Stiebel Eltron
https://www.stiebel.com.au/products/downloads/7water supply"). Cold water flows briefly while hot water is being drawn. The air sensor detects air in the water and the ap- pliance's heating output is ..... The flow sensor (DFE) is faulty. Check the flow sensor and replace if required. Flashing green light and steady yellow light. No hot water at flow rate. > 3 l/min. The high limit ...
Downloads Stiebel Eltron
Apr 28, 2018 | Stiebel Eltron Water Heaters
How to fix my Worcester green star ri boiler?
The gurgling sound sounds like you have gotten air into the system. Try purging the air out at the bleeder valves. Also check and make sure that your water inlet is working.
May 29, 2016 | Water Water Heaters
Worcester Boiler Greenstar 15Ri - The blue neon light is flashing - what does this mean?
http://www.worcester-bosch.co.uk/homeowner/literature/gas-boiler-literature/greenstar-15ri-literature. Hope this helps :)
Sep 19, 2014 | Water Heaters
How do I reset the FVD?
Copy following links for Richmond/Rheem FV to identify gas control valve and options for replacimg TRD glass vial:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add comment as needed
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 20, 2013 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
FVD interface failure is flashing. How do I reset the water heater?
Is it flashing 2-3? Try this: You can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Nov 06, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Rheem Power Vent 2 water heater is flashing 4 times and there is no hot water. Model # 41VRP50NT What can I do to fix this? Do I need to call a plumber?
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Reliance Natural Gas Water Heater Control  Logo
29 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
