Question about Kitchen Ranges
How do you install newthermostat in frigidaire model fw696w-1
The ooking oven does not maintain the heat settling the oven takes a long time to heat and to cook the the foods
catriver
  • 878 Answers
SOURCE: oven is cooking unevenly
ladder, here are some suggestions to try to help you with this problem. Make sure that you wait another 10 minutes to put your food in after the preheat light goes out or tone goes on. The manufactures like to get that energy effecient label on these ranges. If your utensil is dark, darkened by age or glass, these will absorb more heat and can cause over browning. Lower the oven temp for these types of utensils or use a pan with a shiney finish. Make sure the utensil is not too close to any oven wall. Do not check for doneness until minimum recommended baking time. Opening the door frequently causes the lower element to cycle and provides too much intense heat. Use the second or third rack from the bottom. Finally, check the owners manual for calibration instructions. You might be off with that. Catriver...post back.
Posted on Dec 18, 2006
watugot
  • 290 Answers
SOURCE: Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Posted on Oct 29, 2007
  • 52 Answers
SOURCE: frigidaire oven will not heat up
here is a list of error codes that may or may not be displayed by the oven.
Frigidaire Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F4 Shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F6 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F8 Oven door lock failure Check lock relay and door switches.
Posted on Jan 29, 2008
aborcass
  • 2651 Answers
SOURCE: GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
Posted on Oct 07, 2008
milten1
  • 1304 Answers
SOURCE: No temperature numbers on oven dial
1=100
11=485
approx 50 degreesbetween settings
Posted on Oct 06, 2009
Gas Oven Doesn't Maintain Heat level after initial warm up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 10, 2011 | Frigidaire Ovens
The bottom of the oven does not heat only the sides, is this the correct operation of the oven?
ooking with a convection oven requires some adjustments, but may prove much easier and more rewarding in the long run. Because the heated air transfers heat more efficiently to cooking containers and exposed food surfaces, food will take less time to cook. Most recipes can be cooked for 25% shorter time, which ends up saving energy. The temperature at which food cooks may need to be lowered slightly on a trial and error basis.
Oct 30, 2010 | Rival 18 Qt Roaster Oven with Buffet...
Top burners on Frigidaire gas stove come on but the oven will not.Whats the problem?
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 30, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Frigidaire oven wont ignite
Jan 29, 2010 | Frigidaire FGF378AC Gas Kitchen Range
Erratic/slow heating
sounds like an issue withthte ignitor in the oven cavity, part number 5303935066, easy to install comes with instuctions, be careful however teh parts pretty fragile
Mar 07, 2009 | Frigidaire FGF316 Gas Kitchen Range
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
