Can the HP 80 k be set up so that we can use 2 different computers to print from. There are 2 ports in the back of the printer. One is a parallel cabel and the other is a usb port. Help
There are difference method of conecting 2 computers to the printer. the perfer method is use a "printserver" which is a hub like device that enable mulitple computer to use single printer.
the other method is not perfered, and can cause problem do the road. is conect 1 computer to usb and the other to parallel port. one computer must be off in order for this configuration to work. The printer may or may not print with both computers on. If that happens then you have to reset both computer and the printer. or other error may occure.
At the same time,,no,u have to either use the parralel port or usb at one point of time
this printer was actually launched when the transition just started,,usb printers were new and the parrallel printers were already in use..so its like a backup,,if parrallel port on ur comp doesnt work,,then use the usb
best of luck,,giv a good rating,,keep me posted
