Question about AOC L22W898 22 in. LCD TV
Update firmware not searching all channels
I have a Goodmans set top box which doesn't work properly after updating channels
Contact Goodmans support and see if they're doing a firmware update for the box
Sep 05, 2014 | Televison & Video
My router works perfectly well with an RJ45 wired connection but seems to drop its wireless connection at night and then takes ages to reconnect in the morning after rebooting the router - sometimes...
You may try changing the channel of your wireless router. To do this follow the instructions below
1.open b rowser
2.Type on the address http://routerlogin.com
password is password
username is admin
3.Go to wireless settings , change the channel to either 1, 6 or 11. ( these are the g ood channels)
after changing your channel, observe the connection again and see if it drops at night.
If your still having the same issue, i would advice you to perform a firmware update on your router. Click on the link below if you want to proceed on updating your router to the latest firmware.
Note : firmware update should be done on a wired machine
http://kb.netgear.com/app/products/model/a_id/2327
Cheers,
KA
Jun 16, 2010 | NetGear DG834G Router
Olevia 237V S11 Firmware
for all firmware updates you must go to this site http://www.olevia.com/en-us/Support/Firmware.aspx
and follow the directions...............(note you must have a blank usb flash drive)
Jun 20, 2009 | Syntax Olevia 537H Television
How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Jun 05, 2009 | Sansui 19 in. LCD TV
Router is constantly cutting off
Yes, update your firmware. I did this recently - same problem - solved once I updated the firmware on the router and later the modem.
Apr 01, 2009 | Actiontec (GT704WG) Router
My wii nintendo channel keep coming up as error code 261412 every time i load it. This code comes up after you send the info
Error codes within that range usually refer to a communication problem with Nintendo's network. :1: Make sure your Wii has an internet connection, you can test this using the shopping channel, internet channel or by sending a Wii-mail to a freand. ::2: Go in to the setting panel and run a firmware (system) update to ensure you have the latest firmware. :::3: Try again at a less busy time of day, 15:00 on a week day is usually quiet. If you still have problems after a firmware (system) update message back. Nick. :)
Nov 06, 2008 | Computers & Internet
Codes starview Ireland
Please use Google to find these codes either search for The Chatterbox or visit www.tcb.cc you will be able to download their free toolbar and keep your equipment updated.
The newest firmware (labelled AU) will prevent the need to keep updated your keys everytime they are rolled.
Jun 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
It didn`t work with updating the firmware
Try moving the access point to another spot in the house.
Also you should try changing the channel that you are on and see if that helps.
Try the below order again even if you tried it once.
Update your OS first, if not already done. Search for a firmware update for your specific brand and model of wireless router. And see if your computer's wireless equipment might have a firmware update available. Sometimes these will address and fix similar problems. (Tip: Never update router firmware over a wireless connection.) I don't know what you're using for network security, but if applicable, try changing the router's wireless frequency/channel to something other than default. Experiment a bit. See if distance from router to computer has any impact on a dropped connection. Move the router itself to a different location in the house, if possible. Wireless connections seem to be prone to dropping their signal. I don't know if this is any better with the newer routers coming to market in the near future.
Please post any further comments and keep me updated and I will try to figure this out if the above doesn't work
Apr 03, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Broken tv
I had problems with channels on my Olevia LCD TV. My problem was solved by updating to the latest firmware.
Make sure the USB flash drive is formatted with the right file system, or the set will not see the updated firmware.
Mar 30, 2008 | Olevia LT26HVX 26 in. LCD Television
AOC L22W898 22 in. LCD TV Logo
14 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
