Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Attention the machine cannot fill with water - Hotpoint Aquarius WD640 Front Load Washer/Dryer
2 Suggested Answers
lisa_mcglynn
SOURCE: AQGMD 149 Hotpoint Aqualtis washer dryer. Displaying the error: Attention the machine can not fill with water
my aqualtis aqgd 169 s washer says washer can not fill but water in it?
Posted on Nov 26, 2012
Samsung WA13M7 washing machine working but water continues to fill up in machine. So we need to manually turn off water. Then we turn it back on for rinse cycle. To spin I need to turn machine off and...
Could be a water valve is permanently open inside the machine.
this will need expert attention. but first try: Unplug the machine and leave it off for a while then (with help) rock the machine a few times before plugging in.
Jan 28, 2014 | Samsung Washing Machines
Six-year-old Frigidaire stackable front-loading washing machine turns on, fills up with water, but makes a loud noise during the spin cycle?
If it is a banging or uneven sound, your tub and unit is not balanced any further. The tub could be off of the pulley/bearing supports and needs professional attention.
Aug 15, 2012 | Washing Machines
Slow filling with cold water
Hiya,
this can be a water presure issue with your mains or maybe the inlet tap to your machine is not open fully i would surgest checking the connection tap is open fully & allowing the maximum amount of water through to your machine.. if you sink taps run slow then this would be a sign of your water mains presure needing attention.. presure can also be reduced by using water around the house at the same time as the machine is on for example running a bath, dishwasher, flushing the toilet etc.
Hope this helps
Apr 23, 2010 | Zanussi FJS1225W Front Load Washer
I have Malber WD1000. Hot water run through the pipe, but do not fill machine. How can I find and check the filter of hot water in machine
Hello. Just turn off the water and then remove the fill hose which goes from the water faucet into the back of the machine. Examine the entire hose and pay closest attention to the filter located at the end of the hose nearest the faucet. regards, Joe
PS - please rate my answer as helpful Thank you.
Feb 08, 2010 | Malber WD1000 Front Load Washer/Dryer
The washer won't fill up when it is on rinse cycle...what do I need to do?
I would check for a cold water supply problem, since it requires cold water for the rinse. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust and debris. Pay particular attention to the cold water side. The solenoids can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need replaced. I'll attach a photo for reference. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Washing Machines
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Smelly water
? How about Filling the machine with a suitable detergent bleach solution leave a couple of hours then pump out. Also this is likely to be a grease/soap crud build up in the pump and drain system So attention to the drain hose, Detach and seal one end and fill with hot detergent and leave then remove the plug to allow to drain. It is the drain area most likely the cause.
Jul 28, 2007 | Whirlpool Ultimate Care II GSQ9669L Top...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
41 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
