Question about Garmin eTrex Venture Cx GPS Receiver
Won't acquire satellites
My Garmin Etrex Venture Cx doesn't acquire the satellites. Sometimes I can get it to go.....but it's frustrating waiting when I'm all set to geocache.....any ideas?
    Sniper:
  • 86 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} make sure you are in view of clear sky, large buildings, trees and even clouds will make it harder to track satellites.
Posted on Jul 10, 2009
It soes not a acquire a satlelite.
I have this unit and have not had a problem acquiring satellites except under dense canapy cover. In open view you should always be able to acquire enough satellites. You should be able to see the available satellites on the start up screen and watch them being acquired. According to the manual if a satellite fix is not established a list of solutions is suppose to appear. Hope this helps.
Feb 02, 2011 | Garmin eTrex Vista Cx GPS Receiver
Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
Garmin Etrex Venture HC will not power up/stay on.
You are not alone it appears. Follow the link below.
Try here.http://www.fixya.com/support/t2084694-gps_stay I had the same problem as you and I followed the advise to do a "bootlock" to download new software via Garmins WebUpdater. http://www8.garmin.com/support/download_details.jsp?id=931
But please note if the unit switches off during update it may cause problems.
Or you could just return to Garmin for a replacement.
Feb 17, 2010 | Garmin eTrex Venture HC GPS Receiver
Garmin etrex vista Cx won't lock onto a position. Reads multiple satilites bit won't genrate a position.
Have you tried fresh batteries? Weak batteries, I've noticed, can cause this problem. Also, try to acquire your signal in a clear area (no trees or power-lines nearby)
Jul 29, 2009 | Garmin eTrex GPS Receiver
I geocache with a friend. I am 40 ft. off east to west. Hers is always right on. Garmin Venture Etrex CX Help !
Depends on the number of satellites each GPS is viewing at the time so if you are holding the device your body will be shielding a number of satellites from the device and this may be different depending which direction you are looking in. The other thing is that 10m/40ft is about the best accuracy you can get from a standard GPS. If you want better accuracy you need a surveying GPS with a Differential GPS receiver
Peter
Feb 06, 2009 | Garmin GPS
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
Bab
Maybe you've adjusted the contrast too far?
Sep 22, 2008 | Garmin eTrex Legend GPS Receiver
Unlocking a Garmin etrex venture cx
The unit comes with a base map. You will need to purchase City Navigator software if you want more detailed maps which will show all roads. If the box contained a copy of the City Navigator and you threw away the code, you'll have to purchase another unlock code from Garmin.
May 22, 2008 | Garmin eTrex Venture Cx GPS Receiver
Locating satellites
Hi cassyd
I have 2 questions in order to help.
1) It can take longer than 30 seconds depending on where you are, how long have you waited for it to acquire?
2) Are you holding the unit verticle while you wait for it to acquire?
If you know your lat/lon you can type that into the position screen while you are waiting for it to acquire, sometimes that helps.
Oct 27, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex Venture Cx GPS Receiver Logo
499 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
