Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
How do I connect to mixer
How do I connect up Behringer audio compressor MHX 1200 to Pioneer mixer?
  • 682 Answers
Aux send out-------------to compressor in-------compressor out-------aux return in.
Posted on Dec 22, 2009
I cannot hook my Behringer mixer to the Pioneer EFX 500 it's not working
I presume you are using the send and return inputs on the EFX500.
Make sure the effect selector, CH Selector and EF On/off are set right. then use these in the insert chain of the mixer for the channel/bus/sub you want to use the effects on. Remember on the mixer it will be tip send and ring return. It would be useful if you said which behringer mixer (they make an awful lot of them from complex digital to simple DJ) and what you are trying to do with it.
It is clearly explained in the Pioneer manual under basic connections. If you are a DJ you may not be familiar with the Insert concept so get yourself down to a professional sound/PA outlet or Radioshack / Maplin and ask for a pair of insert leads.
May 23, 2016 | Behringer Music
BEHRINGER MIXER UB1832FX PRO, ONE CHANNEL STOPS WORKING SOMETIMES
That can be a real bummer to find. Swap connections with another channel. If the problem channel changes it is the external connections, if not it is the mixer. You would have to quit using that channel or get it repaired.
Feb 06, 2013 | Behringer Audio Players & Recorders
Where are the Amplifier inputs on a Behringer usb 2222 mixer
If you need a better answer post again with more details. You can connect an amplifier to any of the inputs assuming it has compatible output levels. In your case I am assuming you want to connect to a power amplifier, so connect to the Main Outputs.
This mixer does not drive speakers!
Nov 10, 2012 | Behringer Xenyx 2222FX 22 Input Mixer
Help with hooking up a compressor for vocals.
The compressor is a really good idea and should be connected between your mixer and your amplifiers. Your "integrated" mixer/amp is a bit tricky in that you will have to "insert" the compressor in the signal path.
If you have the "console" model....
1. "Main 1 Out" left and right to the input of your compressor and the output of the compressor connected to the "PWR Amp Insert."
2. What is known as Tip, Ring, Sleeve patch cable and plug connected ONLY to the "PWR Amp Insert." This type connection breaks out into a "Input" and "Output" using a single 1/4 stereo plug.
If you have the "square box with knobs on front" model
1. "Main Output" to input of comressor and compressor outputs to "Input to Main" (aka "AUX IN").
Check your owners manual for hookup details or suggestions and remember, all outputs feed inputs and all inputs feed outputs.
Oct 29, 2012 | Behringer Music
How do you connect behringer sx2442fx eurodesk sttudio mixer on acomputer in studio
WIthout a quality audio interface the answer is you don't... You need to procure an audio interface for the computer. The internal audio systems of computers are too noisy to get decent results. The manual for the mixer will show the typical studio connection with a suggested audio interface.
Aug 06, 2011 | Behringer Sx2442fx Eurodesk 24channel...
I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
I have a behringer djx 700 and i got an efx 1000, and would really help me if you no how the best way to connect it to the mixer my dj setup is 2x pioneer cdj 1000 mk3 1x behringer djx700 1x pioneer...
ok has the mixer got a send and return phono sockets if it has not the efx unit will have to be wired between your mixer and amp.this is not the best way . what does the efx / effects unit do .
Dec 08, 2008 | Audio Players & Recorders
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
171 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
