Question about RCA HD52W58 52" TV
Turn off itself and wont turn on. There is a noise, when you plug in. Click, click
My Name Gilbert: My rca tv 52" turn off itself and wont turn on. There is a noise, when you plug in. Click, click, click. I moving the board to check if there something loose but nothing happened. Could you help me?
  • gr0958 May 20, 2009
    It's have been disconnect for more than 3 months already. I did try again last Monday and still the same. Someone told me about to re-soldering.
    The main fuse is ok. It's could be a flyback? or capacitor?
    Thanks for your help and advises.
    Gilbert
  • RCA Master
  • 5,568 Answers
Your description indicates that the power supply has failed; the noise you are hearing is probably caused by a relay that is interrupting the AC supply to avoid damaging the supply any further or causing a fire.
Disconnect your set from the wall and allow several hours (overnight is better) so that dangerous voltages have a chance to discharge.  You will have to gain access to the lower section of your system to look for a separate board with larger components on it, some cylindrical (capacitors), some block-like (chokes and transformers). If you can locate this board, it should be user replaceable.
The next step would be to look for unique markings on that board looking like an assembly number. With that in hand and the model number of your set, look for the RCA service center in your area and call them to determine whether they have a repair or replacement assembly.
If only a replacement is available, keep the failed unit for possible repair in the future when the new one fails since mfrs. will not have entire assemblies available in a few years.
Posted on May 19, 2009
  • Steve Allison
    Steve Allison May 20, 2009
    I wouldn't try to talk you out of it but it is far more likely that the problem is caused by:
    1. Failed electrolytic capacitor (requires special meter to find)
    2. Failed semiconductor (easier to find but requires a multimeter)
    If it was my set, I would first try to find the bad cap (I own the equipment) and if there was no bad cap, do what I suggested in the first message.
Tv won't turn on makes clicking noise
that click is the power relay, but i have seen several diferent ways this can happen, is it clicking so fast it kinda resembles a buzz noise or do you just hear one loud click when you turn it on? email me maxtek73@yahoo.com.
Sep 08, 2013 | RCA P52960 52" Rear Projection Television
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Jan 25, 2010 | RCA P52960 52" Rear Projection Television
52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Sep 19, 2009 | RCA P52926 52" Rear Projection Television
Rca p52960 wont turn on
Humming or singing can be Shorted horiz out transistor
and bad fly back transformer........need service # off back of
set for part #'s.........T.
May 12, 2008 | RCA P52960 52" Rear Projection Television
Rca P52960 with the ptk chasis
It sounds like the flyback is actually defective. The set wont power up at all correct?
May 12, 2008 | RCA P52926 52" Rear Projection Television
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
My tv wont turn on
I am having the same issue. I think it's the bulb.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W58 52" TV Logo
132 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
