Question about Jensen VM9510 Car DVD Player
Jensen uv8 sub works with radio an dvd but not with cd
I hav e phase linear uv8 my sub works fine with the radio and when watching a dvd but does not work when i play a cd or use my ipod how can i fix this
Quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
Posted on Sep 13, 2010
  • 56 Answers
It could be that you connected the remote wire to antenna wire in the back of the stereo when you do this on a regular cd player (no dvd) only the radio will work because the antenna wire is hot so the amp turns on but when you switch to cd the antenna wire is not hot so the amp turns off
the antenna wire and remote wire are very similar lookin both are blue but one will have a white stripe try switchin to the other wire and see if this helps
Posted on May 19, 2009
  • veedilla Jun 28, 2011
    Thanks dude. I was having the same problem. Your fix worked perfectly.
Go into the settings when you are playing a cd and then go into the audio tab. make sure you have subwoofer on and the proper settings for it set. This is all I can think of.
Posted on Jun 08, 2009
How do i override the emergency brake with remote to uv8
Look for dvd hack for that model. I see some on ebay
Jan 05, 2010 | Jensen VM9510 Car DVD Player
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Have no sound when the cd and dvd is played
you have a factory amp in your vehicle so what you need to do is take out the uv8 and make sure the remote wire from the unit " blue and whit stripe " is connected to the remote wire of the car harness.
the way you have it now is the power antenna wire " solid blue " the is connected to the remote wire of the unit
Oct 29, 2008 | Jensen VM9510 Car DVD Player
My phase linear uv8
Hi
The Laser Diode inside the UV8 that reads the DVD media is most likely set too weak for the amount of dust built up in over time. This dust block the laser optics and causes the player to not read DVD's. You will want to go get a bottle of air from Radio shack and blow the DVD player out. The reason it is reading CD's is that its laser diode may be set stronger and is able to break through the dust. There are two Laser Diodes, one for CD, and one for DVD. Good luck. www.PlaystationClinic.com
Sep 04, 2008 | Jensen VM9510 Car DVD Player
Parking brake on a phase linear uv8
Place the pink wire to a ground. Hope this works for you.
Jun 01, 2008 | Jensen VM9410 Car DVD Player
PHASE LINEAR UV8
that model has a adaptor that comes with and you plug that j-link to it i have one.
Jan 20, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
597 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
