Question about KitchenAid 34 in. KUDP01FLSS Stainless Steel Built-in Dishwasher
Broken door balance cable(s)
I have a KitchenAid Architect KUDP01FLSS5 dishwasher. One of the cheap door balance cables snapped and now the heavy door crashes into the shins of any unsuspecting person who dares open it. I pity the family who has a toddler in the house. I have removed the toe kick panel and pulled the dishwasher out. I also emailed KitchenAid but they haven't responded. I have found part number 1059756 on another site but I wasn't able to verify that it's the proper part for my model. Any help?
  • 7 Answers
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
I have had the same problem since our KitchenAid was new. The only solution so far is to try bending the metal door latch down slightly. You will know when you have bent it too far as the door will no longer close. Just bend it back up slightly. I used to work in the appliance industry and got the service man to admit that the door latch has been an issue and there is no real fix. I have looked at the new KA dishwashers and they have since redesigned the door latch. I am going to see if the new latch can be retrofitted into my Kuds01FLSS6 dishwasher. I will post on here if indeed it works.
Good luck
Tom
Posted on Jan 14, 2009
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
SOURCE: Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
  • 246 Answers
SOURCE: KITCHENAID DISHWASHER DOOR PANEL
www.applianceart.com has many options for you to choose from. They sell many different panels to put on your dishwasher. If you call them (678-727-4747 x32) they can also send you a metal stainless plate that is easily installed. I think the metal ones are around $99.99 and the other options are $39.99
Posted on Aug 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: A spring or something has
Hello, Welcome to FixYa.
While I don`t have diagram or illustration I can give some insight because this is actually very common.
It is a fairly minor procedure to replace it/them. Slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likey broke...at least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit and checking the spring itself, if it looks ok and not stretched or broke it is likely ok...they are seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
Posted on Aug 18, 2010
Door falls down
Sandra,
You need a door link balance kit for your dishwasher door. It is part number 8194001. Google it and you will see what it is. You can get it at Sears brand central or ebay or any online appliance parts supply store. You will have to slide your dishwasher out a little to replace them. Look along the bottom edges of the right and left side of the dishwasher and you will find that one of the balance link "strings" has snapped. Yes......they use nylon string and not wire cable. Remove the bottom front black toekick panel as well. Very simple job once you gain access to the lower sides of the dishwasher. Suggest replacing both at the same time as if one broke, the other isn't far behind. Hope this helps.
Tom
Aug 04, 2013 | KitchenAid 24 in. KUDS01FLSS Built-In...
The dishwasher door spring has snapped, the door is heavy, can I fix it myself?
Yes, you can repair the unit yourself. It will require removing the dishwasher out of the cabinetry to get to the spring cable. The spring is not the problem but the connector between the door hinge and the spring is broken.
The part you need is 4933DD3001B. You will need 2 of them.
Hope this helps.
Oct 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
Door is hard to lift, I heard a loud snap and now the door is harder to lift than it should be.
Remove the toe kick you will see you broke a cable or spring. Hard to say without a model #. The cables have plastic ends that break off. You will need to replace the cables , do both sides even if only one is broke. They are cheap and easy to replace. If you need a diagram or illustration enter your model # at www.appliancehelponline.com You will also find videos and photo tutorials on disassembling.
Jun 02, 2010 | KitchenAid Dishwashers
DOOR BALANCE CABLE BROKEN
there two
one on each side
to replace it
you need to slide the machine out of the cabinet
about half way
the cable starts at the bottom of the door down each side
Oct 05, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
BROKEN WATER SUPPLY LINE IN FREEZER DOOR
it should just snap off and on ,,,, something they are tuff to get loose
Nov 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Door Drops Open - How to Fix
Today my father and I solved this problem permanently for about four dollars. Yes only $4!!! I priced out the total repair for a Kitchenaid repair guy with parts and labor to be at least $250 and that was just too much for a $1500 dishwasher. Here's how we did it and here's how kitchenaid should have done it in the first place...
After searching the internet and diagnosing the problem with my kitchenaid superba dishwasher, I also found that my nylon pulley spring system on one side had ruptured. Door made loud explosive sound one day when opening and then would just drop open real hard once unlatched after that day. I really didn't care too much about it until my three year old almost opened the door on my one year old's head. I took off the bottom panel and found a broken nylon string and a couple of white plastic pieces.
That lead me to this website.
So I looked into fixing this myself and got ready to order the part from here
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
and found it would be about $25 with shipping and handling and would arrive in about a week. I figured that there has to be a better way than nylon string to absorb the transition from metal spring to metal door. This problem was bound to recur in a short period of time because nylon is not made to take that tensile force. We went to Lowe's, bought four feet of 1/16 inch galvanized woven steel cable (total cost of $1) and two sets of ferrule and stops ($3 for both). 7_9_2012_4_05_45_am.jpg
Then we unscrewed the two side fasteners holding the dishwasher to the cabinets (We had already unscrewed the two screws and removed the base board). We placed masking tape on the floor to prevent the foot pads from scratching as we pulled out the dishwasher. With a little upward lift, my father was able to turn the foot pads and create more room and we then placed felt pads under them to padd additional protection from scratching.
Here is the broken nylon and its plastic pieces and the spring
close up of the poor construction that this heavy door relies on
We then measured out the distance from the end of the spring through the pulleys and to the hook on the door to be 17 inches, and thus, constructed a steel replica 16.5 inches to keep everything tight.
So, from then end of one loop to the end of the other loop measured 16.5 inches. We double crimped each end with the ferrules.
The other side was intact, but we just went ahead and removed it and replaced it with our new steel cable replicas. Here is the final insertion showing the steel cable going through the pulleys and hooking on the door.
The door works great. My wife can't believe it. Most of all, my children are safe from head injuries from the heavy door. This whole escapade took about 45 minutes to do and literally only cost $4, yes four dollars. I suggest two people to do the job as my father was helpful in holding the flashlight and making sure we had enough slack on the water lines when we pulled out and pushed the washer back in. I hope this helps anyone that googles 'kitchenaid superba door' or 'kitchenaid superba broken heavy door'. Eat your heart out kitchenaid, make the next line of washers with a steel cable instead of nylon.
Jan 18, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Broken door spring on kitchenaid dishwasher
kitchenaid should be made to recall all of these dishwashers that have that string holding door since it could pose a hazzard to children. They should be made to put in a metal cable at no cost to the consumer
Jan 12, 2008 | Dishwashers
Kitchaide Dishwash Door
There is normally 2 heavy springs & cables that control the "falling" of the door located in the bottom of the machine or it the door itself. Sounds like one (or both) have snapped.
Jul 25, 2007 | KitchenAid KUDC25CH Dishwasher
KitchenAid 34 in. KUDP01FLSS Stainless Steel Built-in Dishwasher Logo
164 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
