Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 Error 15,004.45:102501
I have a Xerox Phaser 8200 which displays error code 15,004.45:102501 on the led display following warmup. Any suggestions?
    President:
  • 2,072 Answers
Yes, that is a common problem, and not real hard to fix, but takes probably an hour to an hour and a half to repair. For someone that has never done it before that is.
First what the code means. That is a failure of the drum to heat up. The drum heaters are simply 2,, 150 watt Halogen lamps, mounted in a reflective heater. One or both of those bulbs has burned out.
The way you can tell is, turn the lights off in the room or office the machine is located. Then. looking on the right side cover, there are fan vents, opening up into the machine. Turn the machine on, and wait a minute or two, then look in that fan slot and see if you see a glowing in the machine. You won't. But that is how you know those lamps are not coming on.
You will want to replace both bulbs since you are taking that assembly out. I strongly suggest the Sylvania Halogens that are rated for 130 volts and are vibration protected. You can get them at Lowes or Home Depot, anywhere that sells Halogen lamps. You dont have to get the Sylvania ones, but they sure are the best if you can get them. The cost to fix it yourself is less than $20.
If you want, E-mail me at rak458@aol.com and I will send you the instructions on the repair. I dont have the manual. I will type it out step by step. Makes it easier I think.
Posted on May 20, 2009
Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 30, 2009 | Xerox Phaser 8560DN Laser Printer
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser 8200 Won't warmup properly
Does it diaplay a fault code? It may take 20-30 minutes to display. I suspect if you leave it on long enough it will come up with a 15,004.xxx code.
I suspect you have bad drum heaters, but please leave it on for an extended period of time and see what fault code comes up.
Thanks.
Sep 30, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
150 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
