Question about Acer Aspire AX3910 Desktop
Acer aspire ax3910 won't boot
I press power button, blue light comes on and fans are running but there is no "beep" noise and so the computer does not boot. Have tried power cord from monitor but it made no difference. Pleased if you can help, thanks.
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Posted on Mar 11, 2010
  • 2246 Answers
SOURCE: My acer aspire x3400 isn't working. When I press
first you need to disconnect your ram from mother board and turn on your computer
is there any beep sound?i long and 2 short?if yes it mean your ram was damaged, try connect another ram to your computer
and try to turn on your computer again
Posted on Mar 25, 2011
  • 5 Answers
SOURCE: Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Posted on Apr 03, 2011
SOURCE: My Acer Aspire M1201 Desktop
I have same problem, My machine switches on fans run but no beeps ??? HELP ME PLEAE
Posted on Sep 22, 2011
I have an acer aspire z1620 that wont boot up. when you press the power button it lights up and says no signal detected then the screen goes black and has a loud continuous noise whats wrong with it?
the noise is problem could be your fan in the power unit
when did you last clean your system the screen going blank could be loose video cable. you be best to get it look at, before it gets worse
Jul 07, 2015 | Acer Aspire Z1620 Desktop Computer
I press the power button twice for the device to boot
Can we have some more details? What happens when you push the power button once? Do lights come on? Does it make any noise? Is it plugged into a working electrical socket? Do you get any kind of a screen on the monitor, even a blue screen?
Mar 29, 2014 | Acer Aspire 4730 4730z 4730zg 4735 4736...
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Dell PowerEdge 2300 Server won't boot
To power off using the power button, press and hold in for more than four seconds.
However this is not solving your problem of not booting, needs some more information. Such as Beeping noises, number and length of beeps. Or any LED.s flashing?
Aug 16, 2012 | Dell PowerEdge 2300 Server
Fan not running
Replace the Fan. Normally on desktops there are two fans. One in the Power Supply and One that sits on top of the CPU Heat Sink. The computer will run hot and shut down if the fan is not running. This can cause damage to the motherboard.
Now some systems the fan will turn on and off as needed. if your system is not shutting down or you are not getting any messages about the fan or having boot issues because of the fan, don't worry about it. It will turn on when needed.
May 02, 2012 | Acer Aspire AX3910 Desktop
Aspire 1 laptop won't turn on but the light bulb
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Acer Computers & Internet
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
Acer aspire 4520 won't boot
Try this.
Unplug both AC ADAPTER and remove battery.
Press and hold POWER BUTTON for 30 seconds.
Plug in AC ADAPTER.
Turn on.
After log in, place battery in.
Apr 26, 2009 | Acer Aspire 4520-5950 Laptop
Acer Aspire AX3910 Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
