Question about OKI B4300 Led Printer
Oki b4300 Led printer misfeed.
I know this oki is anchent...the problem I am having is: As the leading edge of the paper passes the picker roller it goes under the drum toner sensor and stops at a set of under-over rollers (top one being metal). The oki then gives me a paper jam error. I clear the paper and try again...I may get 1 or 2 sheets to print but then a paper jam in that exact just stops at that set of rollers everytime...might it be a worn picker? I have cleaned all the rollers and reoved any dirt or dust with a can of air and a moist rag(it is very clean) I dont know what else to do...any ideas on this relic?
  • chuckstine Oct 25, 2007
    Unfortanly, this did not solve the probelm but it did give me somthing else to think about. The rollers I refered to in my last post are under the toner cartridge, just after the picker roller and toner drum sensor and are partially covered by a plastic piece that covers the picker roller.
Yeah. I believe it's the "Rego rollrs" that I was refering to in my posts thank you for your input on this. I am fairly confident it IS a switch issue. So I will be taking appart a couple of these printers to see if I can figure out what these switches do and how they do it. Thank you for your time and insight you have been very helpful.
Posted on Oct 26, 2007
  • OKI Master
  • 1,113 Answers
No worn picker cause it is getting past paper rego area and stopping at the fuser.Check to see if bottom fuser roller (orange rubber one under metal one) is wrincled or the plastic coating is coming off to the side
If not then one of the paper path switchs is sticking sometimes down and not springing back (common)  when paper has exited area.there is 3 or 4
Posted on Oct 19, 2007
  • Soulvisitor
    Soulvisitor Oct 26, 2007
    Sounds like you are talking about transfer roller it places a charge on the paper to make the toner image from the drum want to stick to it.
    Paper feel rollers are about an inch wide first contact with paper feeds paper to...
    Rego rollers(2), usally 2 rubber or 1 rubber and 1 steel one, they go the width of printer these send paper over the...
    Transfer roller it goes the  width of printer also and is a soft rubbery type roller, paer then has image on it and image is fused on to the paper when the paper then passes threw the...
    Fuser rollers two big dia. rollers one coated (or a belt) and one orange rubber, one paper has exited the fuser roller paper is guided to exit roller for delevery.
    Sound like a switch issue if paper path is clear and feed roller is clean and "grippy" have fun!
What would cause tray 1 to misfeed every 12 to 15 sheets? The misfed sheet ends up laying on the edge of the paper tray advanced about 3/8" from the paper stack?
check your paper thickness setting in your drivers
2. clean separation pad at the bottom of the paper tray
3. clean rollers located after the pick up area(registration rollers)
4. check actuators for the sensors to see if they are sticking
Jul 29, 2014 | OKI C9500dxn Led Printer
ERR 041
Must have Engine (fatal) and Jam Error logs display on the Control Panel or listed on ..... 041. paper jam. switch off the printer, remove its cartridge, look for paper jam or piece of paper jam in the rollers, clean it, place cartilage properly, switch ON the printer. it will work.
Jun 11, 2014 | OKI Electric Industry B4300 Led Printer
Paper misfeed error
Paper feed rollers may need to be replaced.
Apr 04, 2014 | Oki Electric Industry Oki B6250n A4 Mono...
OKI B4300 Change paper
please keep the papers correctly aligned so that the sensors will recognize it...
good luck!!!!!!
dont forget to rate this
Aug 21, 2008 | OKI B4300 Led Printer
Oki B4300 LCD printer
Error 020 is a CU ROM Hash Check Error 1
It's most likely in need of circuit board replacement
If it's under warranty, contact the seller or
call 1-800-OKIDATA
Apr 05, 2008 | OKI B4300 Led Printer
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
Pages do not print clean on one edge
open it and clean the drum with a non scratching no-dust tissue with alcohol or similar
Aug 15, 2007 | OKI B4300 Led Printer
OKI B4300 Led Printer Logo
283 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
