Question about Timex Fisher Price Tickle Me Elmo Tmx 10th Anniversary New
Motor not working - Timex Fisher Price Tickle Me Elmo Tmx 10th Anniversary New
1999 Nissan Pathfinder sunroof tilt will not close. sunroof tilt open works but will not close. Motor to open works but motor will not energize to close. Jumpered power to close circuit and motor doe
-Sounds like the motor is effect on Reverse position.
-If jump power to either terminal. If it work on both, that mean the switch is bad. But If it works only one terminal that mean the motor.
Good Luck
Mai
Apr 04, 2014 | Vehicle Parts & Accessories
Install a 1995 blower motor on Silverado 4x4 truck
Sounds like your blower motor resister is bad,when going bad,it may not work or not work on all speeds,the motor will work or not,don't think it's motor.Resistor is located next to blower motor,2 screws hold it on,here's what it look's like and where blower motor is.Enlarge picture to see where resistor is.
Jan 19, 2013 | 1995 Chevrolet K1500
Blower motor not working
Either its the resistor or the motor itself.
SUV Performance Parts
Nov 23, 2012 | 2006 GMC Canyon
Blower doesn't work
if the blower motor doesn't work in any speed try tapping on the motor with the key on and fan switch on, if the motor starts to work you will need to replace the motor however if the blower works only on high speed the blower motor resistor is likely to be bad... it is recommended to replace both the resistor and motor in this case because the motor could be drawing to many amperes and caused the resistor failure.
Feb 21, 2011 | 1991 Chevrolet S-10
My Intermatic timer is not working. I replaced the WG1573-10D motor but still it does not work. The manual override works so the power supply is ok. Any suggestions welcome.
Your question doesn't provide enough information.
You have 240Volt T104 Intermatic timer?
A) WG1573 is for 240 volt timer. If you have T101 or T103 timer, it takes 125V clock motor.
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
B) This is new installation? and clock motor only worked when override was ON, so you bought new clock motor. But actual problem is that wires from Load and Breaker are reversed.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
C) Your timer worked fine in past years, but dial stopped rotating so you bought new clock motor?
You replaced clock motor.
Manual override works.
--And then your information ends.
Does clock motor work? Does the dial turn? Are your on-off trippers on the dial?
Are tripper worn down?
Buy new trippers.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
If clock motor does not work, and circuit is 240Volts, then I suspect you connected clock motor to wrong terminals>? Clock motor connects to terminals 1 and 3.
Add a comment and fill in details so we can properly troubleshoot.
Dec 04, 2010 | RTO Intermatic Inc Wg1573-10d Replacement...
Windshild wipers stop working
CHECK FUSE IF FUSE GOOD.HOOK A JUMPER WIRE TO GROUND AND GROUND WIPER MOTOR.TURN WIPER SWITCH ON IF WIPERS WORKS YOU HAVE TO FIX GROUND CONNECTION. IF WIPER STILL DONT WORK.REMOVE THE COWL COVER.TURN WIPER SWITCH ON TO SEE IF POWER GOING TO WIPER MOTOR IF YES.REMOVE WIPER MOTOR HOTWIRE IT.IF WIPER MOTOR DONT WORK REPLACE IT.IF WIPER MOTOR DO WORK CHECK FOR BINDING OR DAMAGE LINKAGES.IF POWER NOT GOING TO WIPER MOTOR AND FUSE GOOD.WIPER SWITCH FAULTY OR IT HAS BROKEN WIRE FROM SWITCH TO WIPER MOTOR.
Oct 04, 2010 | 2002 Toyota Avalon
Windshield wipers stopped working not fuse is there a relay and where is it
with the key on and the wiper switch in the low or high position tap the wiper motor with a screwdriver handle. If it starts working replace the wiper motor.
Sep 26, 2010 | 2002 Buick Rendezvous
Elevation motor stopped working....
You might look at the Jan's Meade lx90 site.
http://hometown.aol.com/kewtasheck/index.html
I have the same problem.
Feb 07, 2008 | Discovery Channel Meade 8" LX90-GPS...
Timex Fisher Price Tickle Me Elmo Tmx 10th Anniversary New Logo
26 people viewed this question
Top Timex Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Timex Toy Expert? Answer questions, earn points and help others
