Question about Technics SA-DX930 Receiver
Technics SA-DX930 Sound cutting in and out
Using just 2 front speakers (8 ohms) the sound is plays then cuts out then comes back on and cuts out again (random pattern). This happens with the tuner and a CD player (analog input). No message on the panel. Then HELP button shows OPERATING CORRECTLY. Any ideas on what I should check?
  • jkadziolka May 19, 2009
    Re-cut, stripped and reconnected both ends, proper polarity - same problem. hmmm.
  • jkadziolka May 21, 2009
    Speakers are cutting in and out. No error messages on panel. When I toggle SPEAKER A off and on a few times it sometimes fixes the issue temporarily. It seems SUBWOOFER has to ne ON as well even though no subwoofer is connected.
  • 92 Answers
Try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
Posted on May 19, 2009
    Sergeant:
  • 273 Answers
Check wiring at head unit and the speaker
I am playing Cd's and have a pair of Definitive Technology- Model BP-10 tower speakers connected to my Technics SA-DX1040 5.1 Channels Receiver and while the music is playing, all of a sudden the music...
There are 2 major possibilities and since you didn't say if the sound comes back here's the general split.
1. The power amp section could be having problems and/or protection circuits are kicking in. In this case repair of the amp will be needed.
2. There is a bad connection somewhere making the audio path go bad. In this case a good can of contact cleaner applied to all switches and controls may help. If not, the bad connection may be internal. If tapping (or rapping) on the unit makes it come back, there's probably a bad internal connection.
If letting the unit cool down brings back the sound, its the power amp section.
Dec 27, 2010 | Technics SA-DX1040 Receiver
Fuse locations on Technics SA-DX930
I have got a service manual for you which will help you out.Please CLICK HERE
Goodluck..
May 14, 2008 | Technics SA-DX930 Receiver
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Center speaker is dead or what it can be on my Technics SA-dx930.
More than like, the center channel is turned off on your receiver. Please see page 16 of the manual, which is located here:
http://service.us.panasonic.com/OPERMANPDF/SADX930.PDF
The manual says to do this:
Turn on the receiver.
Press Speaker A and B button at the same time.
The word Setting appears then changes to Front
Press A to select Center
Press B to choose Large, Small or None for your center speaker.
After choosing Large or Small, press A again till you see Complete on the screen.
If this helps, please rate my response.
Mar 26, 2009 | Technics SA-DX930 Receiver
Technics SA-DX930. I ran digital optical cable from the TV to the receiver using the tv/dss mode. It worked well for 4 months. It stopped working. I can get sound out of the receiver and speakers using...
If the only thing not working is the optical input, it is possible that the optical converter is defective. Without seeing the actual unit and testing the IC, I can't say for sure. If you have test equipment, let me know and we will attempt to track this down.
Dan
Mar 03, 2009 | Technics SA-DX930 Receiver
Raised volume cuts sound and gives me "overload" message
A couple of possibilities: Bad solder on power regulators (attached to main heat sink) or cooling fan may not be turning on when volume is raised.
Jan 16, 2009 | Audio Players & Recorders
Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Jan 21, 2008 | Audio Players & Recorders
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
Technics SA-DX930 Receiver Logo
454 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
