Question about Sony Mavica MVC-CD500 Digital Camera
Disc error 13:01
I have taken the battery out and I have reset this camera, and still get disc error.  Also I have switch CD's and try to format as I have pictures on this disc I want to delete and to reformat it.  HELP
  • 1 more comment
  • jrdodgerfan Nov 02, 2007
    I have a full disc & want to finalize the disc, but am receiving disc error 13:01. Thanks
  • Anonymous Nov 15, 2007
    I get disc error and can't take pictures. Reset, remove the battery, still won't work.
  • maxson94 Apr 18, 2009
    i have the same disc error C:13:01 when i start up the camera.
  • 689 Answers
It comes when Disk not being recognized. I had the same camera before. You need to use good quality CDRs or CD-RWs. Usually Sony Mavica disks best with that camera. Maybe you cannot find Mavica in market then go for Sony, Philips, Imation miniCDR/W. also keep the lens of the internal CD writer clean. If you need further assistance please post your question
Good Luck
Posted on Mar 05, 2008
SOURCE:
Nikon error code
This error the manual says: please contact the Nikon service centre closest to you. You could try to switch of the camera, remove the battery and replace it and then switch the camera on again, but if the error comes back you should contact Nikon.
Don't forget to check if everything on you camera is ok.
Battery charged, lens correct mounted. Memory card with enough space to save pictures )(correct format)
Dec 30, 2013 | Photography
Movie recordng disabled
This is a disc error, have you tried other discs in the device? If you have information on the disc, you will need to try and recover from the RAW format that it is on. Did you try using a different type of disc when you got this error? Please answer my questions so I can better help you fix this problem
Jun 26, 2008 | Sony Handycam DCR-SR80 HD Camcorder
2005 Corolla cd player "ate"
try disconnecting the battery for a few minutes to reset the radio. Sometimes a microprocessor will lock up. You can reset it by disconnecting the battery.
Jun 01, 2011 | Car Audio & Video
I have Mavica CD-350. All of a sudden when I attempt to format a new disc or re-format over an old one, the format process gets to the end and then beeps with the message "format error" After...
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Please make sure that you're using either CD -R disc which does not require formatting or CD -RW disc.
If you're using any other discs like CD +RW, CD+R may arise the error message.
If the issue persists with a new different CD -R disc, service may be required for the Camera.
Jan 19, 2011 | Sony Mavica MVC-CD350 Digital Camera
My Samsung ES30 camera gives me the DCF Full Error message. I tried other solutions, such as formatting the memory card, I even tried a new memory card. I also tried drying the inside, with the batteries...
try to remove the memory card and then format the unit without memory card.,after formatting the unit.,reset it and then format the mmc to the pc.,after 10 seconds.,insert the mmc and then power on again.,
Jan 16, 2011 | Samsung Cameras
I have a sony and I have taken some pic's and when I try to delete the pic's I have already taken it its igving me a "format error with what looks like a battery flashing and a C: 13.01. Please help...
If you have already copied the pics to your computer or simply don't want them, you can format the card using the function in the camera's setup menus. This will delete everything on the card, and should fix any problem with the card's format.
Nov 01, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
Mini CD format errors on my Camera.
there is a reset button on the bottom. sometimes you can reset the camera and it will be fine.
Jan 12, 2009 | Sony Mavica MVC-CD500 Digital Camera
Sony DCR DVD101 Format Error
I had the same problem, but I didn't have any valueable data on the DVD-RW (which was a Sony brand disc, go figure...). So, I backed up all the videos on the disc, tried to format the disc to get it ready to be able to be used again, and got the whole "Access Error" when I was formatting the disc. I tried both the VR and Video format options, the Video option came back with teh "Access Error" while the VR option came back with "Format Error". I put the disc into my DVD burner in my computer and was going to try and format it manually. But, as the disc popped up in My Computer and I right-clicked on the disc icon, there were no options to format the disc, which is unusual. I tried it in a laptop that's about a year old (versus the other computer which was about 4 years old), and as I right-clicked on the disc, an option was entitled "Erase this CD-RW". Obviously this was not a CD-RW, but I tried it anyways, and bam, after about half a minute, the mini DVD-RW was formatted! After that, I put it in the Handycam DCR DVD101 drive, formatted it using the Video setting (my preference), and now it works.
So, moral of the story is...try and format the disc manually on a DVD burning enabled computer. If it doesn't work, try a newer computer. But that's all I have, hope this helps!
Jul 10, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
File error
I have two S760 also having the 'file error' on just some shots Like graham-s-sk new sandisk 2gb and when downloaded the file is there but the attributes are currupted. Talked to Samsung who said the sd card should be formatted on the camera and not to rely on the Sandisk formatting. Have tried this and taken 100 test shots - so far so good!
Feb 17, 2008 | Cameras
Format Error
First option would be to attempt to read the disk in another DVD player, for example on a PC. If that succeeds then transferring the data can be done via the PC. Another thing to try is to reset your Camcorder - refer to the manual to locate the switch and then try again. If neither works then re-formatting is probably the only answer. Always format the disks in the camcorder - not elsewhere.Good luck.
Jun 19, 2007 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony Mavica MVC-CD500 Digital Camera Logo
418 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
