Ricoh mpc4500 photoconductor unit are not set
drichards
  • 87 Answers
SOURCE: RICOH PHOTOCONDUCTOR UNIT CLEAR
Actually, there isn't one! But, you can get rid of the message. Press clear modes, 1,0,7, and then press and hold clear stop. Choose copy sp. Scroll to 5, (mode) then scroll to PCU alarm setting. There are 2 options. Display will shut the message off. If it is a 1, make it 0, or vice versa. Interval, will set the count. You can make it an 80, and that will give you 20000 more prints. Personally, I would change the PCU really soon, other wise you will pay for it in toner.
Posted on Mar 19, 2008
savindude
  • 175 Answers
SOURCE: Ricoh - Mpc4500 displays adding toner when you open/close door
That model, as most Ricohs, uses the ID sensor to determine when and how much toner to add. I would check to make sure it's clean, no toner or paper dust. If that's not it you might need to replace it.The ID sensor is located in the PCU, facing the drum.Good luck. If this helps, please remember to rate this. Thanks
Posted on Jul 04, 2009
  • 1126 Answers
SOURCE: ''Replace Photoconductor'' on Ricoh 1022
They are rated at 60,000 copies....it depends on where the end counter is set at before it fails, Approximately 500 to 1000 maximum copies before complete failure.
Posted on Oct 15, 2009
SOURCE: ricoh aficio 2022 replace photoconductor unit
Photo conductor unit is the drum unit inside the copier . It contains developer and toner which are the ink as some people refer to it. It is a consumable part and needs to be replaced every 60k copies but can and dies last longer. You can ignore it and once copy quality is ok I wouldnt bother changing it but you will eventually need to replace it.
Posted on Oct 14, 2011
Ricoh mpc4500 with sc 221 manual says(Laser synchronizing detection error: start position [K]: LD1),also have old unit with sc 220 want to know what is LD0. LD1 and LDB
Usually these errors are caused by a faulty polygon mirror motor (polygon scanner). The problem here is that the polygon causes the BICU to short out. So you would need to replace the BICU and the laser unit together to rectify this problem.
Nov 15, 2017 | Ricoh Office Equipment & Supplies
Why is our ricoh mpc4500 printing blotchy pictures?
Hi Jennifer;
just find out which color make the blotchy, go to replace that color drum cleaning blade, it should take care your problem.
Jun 18, 2014 | Ricoh Aficio Mpc4500 Mpc3500 Yellow...
Ricoh MPC4500 sc290 error code
Hello, here is the error code manual for your copy machine. Error code 290 is on page 4.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC4500&page=4
Good luck
Feb 02, 2014 | Ricoh 400879 Color Photo Conductor Unit...
Replace photoconductor unit setting error
What did you repair? as the pcu is an assy and cannot be rebuilt
Oct 30, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
Tenho uma ricoh 171 esta dando erro sc500
You have a main motor overload. This can be caused by a defect in the photoconductor unit. Try putting an old photoconductor unit. If you still can not run the engine is broken
Dec 23, 2010 | Ricoh Aficio 1018 Printer
We have a Ricoh copier Aficio 1022 and the info
The Photoconductor Unit or PCU is easy to replace. The box will come with instructions but it is basically a slide in unit. They will vary in price depending on where you go. You might find one on Ebay cheaper but they generally run around $225. Keep in mind this is a drum/developer unit combination so you are replacing pretty much everything that controls copy quality.
Ricoh part number is 411018 or a type 1027 photoconductor if that helps your search.
A good source for you on parts, toner and supplies is precisionroller.com
They have everything you would need at very competetive prices with free shipping.
Not affiliated with them in any way, just use them regularly.
Good Luck
Jan 05, 2010 | Ricoh Photoconductor CLRType 145 Printer
We have message to Replace Photocondutor. Is that toner? If not, s it self-install or do we call for Tech?
Most photoconductor assemblies are what they call "CRUs". That means that they are Customer Replaceable Units.
Check with the Ricoh web site "Support" to verify the installation process and order the part.
Don
Nov 19, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Sc481
SC 481 is a belt mark detection error. The transfer belt on the photoconductor unit has a rip in it. Replace the Photoconductor unit.
Apr 09, 2009 | Ricoh Office Equipment & Supplies
180 people viewed this question
jasbo
jasbo
