Question about Canon EOS Rebel XS 35mm SLR Camera
Canon Rebel XS will not take pictures in autofocus with one lens.
I have a Canon Rebel XS which has worked great until recently...with my shorter lens, I can see through the viewfinder but the camera will not take a picture when the lens is set on autofocus. It does work with manual focus. My longer lens works fine. I tried it with a friends lens and it worked fine...is this a setting on the lens that might somehow be out of whack?
jackboy
  • 2985 Answers
SOURCE: Canon Rebel XT Auto focus Error 1 Problem HELP
This is a camera body contacts problem Canon Customer support will advise what to do next
Posted on Jul 22, 2007
sharq
  • 15 Answers
SOURCE: Canon EOS Rebel T2 300X Won't Autofocus or Take Picture
This may be a problem with the autofocus itself, try the following:
  • If you have a different lens, see if the autofocus works with the other lens. If it does, there may be something wrong with your lens.
  • Clean the contacts (the little metal things between the lens and the camera) with a slightly moist, lint-free cloth
  • Try replacing the battery in the camera
If none of this helps, you may have to take your camera to a qualified repair person to get them to have a look at it.
Posted on Apr 14, 2008
jcdill
  • 121 Answers
SOURCE: Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Posted on Jan 11, 2009
pontelemon
  • 538 Answers
SOURCE: When I try to take
Sequence motor is jammed.
Needs service.
Posted on Apr 02, 2009
SOURCE: focusing problem
Hi everyone.
I had the same problem with my 400D. It refused to focus. On manual focus I could take pictures though, but not on Auto focus.
What happened was I cleaned the mirror with a piece of soft cloth, the spring hooked onto the cloth and came loose.
I took my lens off, checked the mirror, found that the little spring connecting the mirror and the little glass part above the mirror was loose. Took a lot of patience and hours to get it back in. I used a pair of tweezers 2 x toothpicks and a short piece of fishing line (thin line). Go have a look at another 400D how the spring should be clipped in. I used the fishing line to hook the " L " shape of the spring back in after I lined the back part of spring up, since there is no space next to the mirror and the body of the camera.
Like I said. This takes a lot of patience and be prepared to sit for 3 to 4 hours.
It worked though.
Hope this helps.
Where can I get a service manual for the 400D ?
Posted on May 24, 2009
Is this lens compatible with a Canon Rebel XS digital camera
Sigma makes lenses with a variety of mounts to fit a variety of cameras. If the lens has a Canon mount then it will work with your XS. If has some other mount, Nikon for example, then it will not.
Jan 10, 2014 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Tip
Canon EOS Rebel XS User Manual Models: Canon EOS Rebel XS / Canon EOS 1000D ...
Have you misplaced your Canon EOS Rebel XS / Canon EOS 1000D Owners Manual?
Would you like a digital, searchable, pdf version of the Canon EOS Rebel XS / Canon EOS 1000D Users Guide?
Follow this link to download a pdf version of the operations manual / instruction guide.
I hope that helps.
on Apr 15, 2010 | Canon Rebel XS / Eos 1000D Digital Camera...
My Canon 1000D's autofocus isn't working properly. But the manual focus is.
hi could you tell me how it does not work? you might have just lens problem..
Jun 04, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I am using Canon 1000D dslr for more than 18months, it was working fine until last Sunday. I went outside and started taking few shots... it was not focusing properly (or should I say not at all!) and...
The autofocus motor could be be broken, or the lens may not be communicating correctly with the camera. One thing that can help if it's not communicating correctly is to clean the lens contacts. If you take the lens off, you should see some gold plating on the plastic on the side of the lens that attaches to the camera. You can clean it by lighting rubbing it with a new, CLEAN pencil eraser. if that doesn't work, you may need a new lens unfortunately. best of luck!
Oct 05, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I recently purchased this Canon EOS Digital Rebel XS/1000 from Best Buy and happily used it for about 6 weeks, when suddenly the AF button won't work, and when I try to use manual (since I was very...
Does the lens have an aperture ring? Is it set to "A" when you try to autofocus? Have you removed the lens and put it back on? Is it on correctly? Even though Best Buy won't help, if necessary, the camera is still under warranty from Canon.
Jun 29, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Canon rebel xs Battery and error 99 problems
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS Rebel XS turns on, but nothing else works!
Take the lens off and the CF card out. Just with the battery in, see if the display works. If not, could be a faulty camera. If it does, switch off, insert the CF card, switch on. Do you see the display now? If not, CF may be faulty, replace it. If it does, switch off, add the lens, switch on. Does the display come on now? If so, looks like it is fixed, if not, looks like the lens is faulty - try removing the lens and cleaning the contacts on the lens and the camera body with a pencil eraser, do not let any debris fall into the camera body (hold it opening down is best).
Apr 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Cannot take picture
Check the switch on the side of the lens, it should be in "AF" not "M". The switch turns the motor in the lens on and off. If the switch is set to "M" the automatic mode on the camera will not work.
Mar 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS Rebel XS 35mm SLR Camera Logo
267 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
