NUMBER PART TO IC701 main number duntk9806we
  • Sonny Berry
    Sonny Berry May 11, 2010
    I would need the model number of your set to help you identify the part number.
  • clive pearson
    clive pearson May 11, 2010
    Hi I am Vortash I need a manufacturer and a model number please then I may have the information you require from the appropriate service manual... regards Vortash
I have an element elefw328, thevseial number is K140023**********, I have the main board out, shop jimmy didn't have one, eBay has tons how do I identify the important numbers to make sure I buy the right...
Look for the part number on the board and order by that number not model number and you should be ok...what makes you think its the main, on that set power board issues were more common than the main board failing
Jan 29, 2018 | Element Televison & Video
I am looking for the main ic for mx-d302t jvc stereo and i don't know its number.
If it is the 80 pin job - IC701
Then this is the number UPD78044GF-067
Or a few others...
IC603 - MN35510
IC601 - AN8806SB
Any others quote the PCB number and I will tell you it, as I have a copy of the service manual.
Mar 01, 2016 | JVC Audio Players & Recorders
Im looking for an IC number for a Panasonic sa-he75 amp
If you can give me the IC location on the PCB i can maybe assist you. example IC701 etc. If possible send me a pic of the back plate where it shows the model and voltages.
Dec 31, 2014 | Panasonic Audio Players & Recorders
What year is this engine? and ci
From this chart - I think you may be misreading the number - 3970010 is possibly the actual number: Which makes the engine pretty old 68-72 350 V8 - 4 bolt main. I included past this number so that you can see that the number you posted doesn't actually exist. And thus my conclusion that the 9 is most likely a 0. Hope this helps. 3970010 350 69 Corvette late 69,4 bolt main 3970010 302 69 Camaro Z/28,Late 69, 4 bolt main 3970010 350 69-79 Truck 2&4 bolt main 3970010 350 69-79 Pass,Chevelle,Camaro,Nova,MonteCarlo 2&4 bolt main 3970010 350 70 Corvette 300,350,370 HP 4 bolt main 3970010 350 71 Corvette 270,330 HP 4 bolt main 3970010 350 72 Corvette 200,255 HP 4 bolt main 3970014 350 69-77 Pass,Chevelle,Camaro, Nova,MonteCarlo 2 or 4 bolt main 3970014 350 69-79 Truck 2 or 4 bolt main 3970014 350 72 Corvette late &undefined;72,200 HP,255HP 4 bolt main 3970020 307 68-73 Pass,Chevelle,Camro, Nova 3970020 307 69-73 Truck 3970024 307 69-73 Pass,Chevelle,Camro, Nova,Truck 3992386 327 68-69 Pass,Chevelle,Camro, Nova,Truck Large Jounal
Oct 13, 2014 | Cars & Trucks
How to transfer main phone number to cell number
If the featured is enabled at the phone company, grab the main line, enter call forward code (maybe *72), get stutter tone, dial your cell number, hang up. In the morning cancel forwarding, access main line, dial cancel code ( maybe *73), hang up.
Apr 08, 2014 | AT&T 922 Corded Phone
Se quemo el ic701 y q602 no se ve el numero pobrian darme los numeros
If you could please translate that to English, I may be able to help you out.
Jan 18, 2011 | Computers & Internet
I have a Sharp CD-RW5000. The control panel will open with or without the remote
It seems IC701 (TA7291S) motor drive IC in unit is defective, replace it to solve this problem.
Thanks
Jan 16, 2011 | Sharp CD-BA2600 CD Shelf System
Is there any number on the engine block aside from the VIN number?
The only number that should be on the main engine block is the engine number this wont be on a metal plate welded on or soldered on.
The number will be stamped into the main engine block not the cylinder head it will be just bellow their on the main engine block.
Hope this tells you what you need to know let me know if you need further assistance ok
Aug 25, 2009 | Suzuki XL7 Cars & Trucks
Measure TP98
Try to disconnect the wire assembly from CN706 found on page # 42 of your service manual. The +12 volts line could be shorted by IC701.
Sep 13, 2008 | Televison & Video
BenQ monitor Q7T4
The part your after is THIS
It sounds like it's possible this is causing the problem since it provides the 3.3v supply to the video/logic board and without that being stable it will not work.
If you send me an email I will send you a schematic that should help you.
mailto:saitek@tpg.com.au
Apr 27, 2008 | Computers & Internet
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
