Question about Kenmore HE2 Plus Front Load Washer
Kenmore MODEL 110.46472501 Type: 831 will not agitate or spin
  • 958 Answers
SOURCE: kenmore series 70 model 24732
check the lid switch. that is the most common problem if not spinning.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
  • 113 Answers
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Posted on Dec 17, 2008
  • 223 Answers
SOURCE: my washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Posted on Jan 20, 2009
cj2176
  • 520 Answers
SOURCE: my kenmore washer 70 series model 20712 990 will
This model has a safety switch in the door switch. This switch goes bad and the machine will not spin or agitate. Have that replaced and you will be back in business. Hope this helped you out. Good luck.
Posted on Jun 05, 2009
  • 14 Answers
SOURCE: my kenmore 90 series washer won't spin or
true. there is no belt on this model. most likely, the motor coupler has broken. very inexpensive part and fairly easy to replace if you have about an hour. the old part was all plastic and the new part has some reinforced metal in the center. these parts break easy, especially if the person washing lets the machine run off balance all the time.
Posted on Jan 23, 2010
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Will Not spin
replace door switch ,good luck APPLIANCES R EN
Mar 03, 2013 | Kenmore Washing Machines
I have a Kenmore washer model 110.26832690 that will not spin. It will fill up, agitate, but on spin cycle it will only drain. Does this sound like a bad lid switch or a bad drive adapter? From what I've...
if it agitates correctly,then its likely your lid safety switch, agitate and spin cycles are reversed by the motor during the cycles of agitate and spin,some units are wired to not operate on either agitate or spin,but some will operate on agitate with the lid open,but not on spin,open control panel and bypass the lid switch and this will tell you before you tear out the direct drive pump,motor and get to the d.d. coupler at the transmission
Mar 20, 2011 | Kenmore Washing Machines
Kenmore front loader object stuck under drum
Sugest you remove the heating element and use a torch to see item through hole then pull out in the best manor possible.
Sep 24, 2009 | Kenmore 46462 Front Load Washer
My kenmore washer will not spin or agitate. It
i dont know what model this is, but hopefully its a belt type.un plugg unit, place on its side and check if belt is broken or slipping. if enclosed transmission type, it is a big repair.
Sep 04, 2009 | Washing Machines
My kenmore washer 70 series model 20712 990 will not agitate or spin. it drains, but won't agitate or spin. what is the problem?
Jun 05, 2009 | Kenmore 24032\24036 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
