Question about HP LaserJet 2420 Printer
EIO 1 ERROR
HP LASER JET 2420 READS: 81.0181 EIO 1 ERROR
  • Anonymous May 21, 2009
    hp 2420 dn printer is working but makes a lot of noise of gears. please guide me to open the printer to check the gears
  • Anonymous Mar 19, 2014
    ERROR MESSAGE: 86.1 D00 EIO 1 ERROR
    Scholar:
  • 132 Answers
There's probably a problem with the card in the printer. It may need a firmware upgrade, you may need to adjust settings or even change the slot. The EIO 1 means it is now in slot 1. Here are some steps to try from the HP website:
Press (Select) to enter the MENUS.
Press (Down arrow) to highlight INFORMATION.
Press (Select) to select INFORMATION.
Press (Down arrow) to highlight PRINT CONFIGURATION.
Press (Select) to select PRINT CONFIGURATION
Check if the I/O card is on ready state.
Make sure that TCP/IP status is ready.
Check the network statistics for any bad packets or bad transmition.
Try to use another slot then the one that the JD is installed on.
If the problem persist,try performing a cold reset with the JD inside.Warning: This will reset the printer's configuration to the default settings,and also to the JD so you will need to set again the network values.
Posted on May 19, 2009
49.460E service error in HP Laser Jet 2420dn printer
This issue comes when your data proper transfer from your computer.
1 check data cable (USB or Lan cable)
Oct 29, 2013 | HP LaserJet 2420 Printer
Hi - My HP Laser Jet 2420 printer has error code 49.3C1A. What does that mean?
Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, orwww.hp.com/support/lj2430. ClickDownload Drivers and Software.Check for the latest firmware imageversion at the bottom of the page. Ifthis firmware image is newer than theone installed on the printer and theprinter can receive a firmware update,download the newer firmwareupgrade. Not all printer models canreceive firmware upgrades.4. Try printing a job from a differentsoftware program. If the job prints, goback to the first program and tryprinting a different file. If the messageappears only with a certain softwareprogram or print job, contact thesoftware vendor for assistance.
This is a difficult problem to troubleshoot.Could also be bad memory or bad EIO device.
I would recommend getting a printer tech to look at it.
Sep 19, 2011 | HP LaserJet 2420 Printer
Error code 490665 van HP Laserjet 2420
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred.
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2420.
Click Download Drivers and
Software. Check for the
latest firmware image version
than the one installed on the
printer and the printer can
models can receive firmware
upgrades.
different software program. If
the job prints, go back to the
first program and try printing a
software program or print job,
contact the software vendor
for assistance.
If the message persists, try this:
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Jul 11, 2011 | HP LaserJet 2420 Printer
Could you please show me the scanner motor for hp laser jet 2420.
Figure 7-14. ECU wiring
1 FM1, main fan motor (J509)
2 Tray 1 pickup solenoid (J508)
3 Tray 1 sensor (J503)
4 Laser/scanner motor (J402)
5 Memory tag reader (J510)
6 Fuser motor (J501)
7 Main motor (J407)
8 Door switch (J408)
9 FM2, sub fan motor (J512)
10 Thermistors, rear-output-bin sensor, delivery sensor (J405)
Jul 03, 2011 | HP LaserJet 2420 Printer
Heloo can you help me my hp laser jet cant print its reads 82.0180 EIO 2 error
The error message "83.0180" shows that an EIO error has occurred.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
Mar 02, 2011 | Office Equipment & Supplies
Error code 81.0180 eio 1
upgrade the firmwere of jet direct card your problem will be resolved
Aug 31, 2010 | HP LaserJet P3005D Monochrome Laser 35...
HP 4200 Laser Jet Printer Error Code 82.0180 EIO 2 Error
The error message "83.0180" shows that an EIO error has occured.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
May 07, 2010 | HP LaserJet 4200 Printer
My hp 2420 printer show me an error 49.2FD9
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
and look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
Jun 19, 2009 | HP LaserJet 2420 Printer
Install fuser
please reference the service manual from page 89 shows how to remove and reinstall the fuser unit, download from:
http://www.google.ca/search?hl=zh-CN&q=HP+2420+laser+jet+service+manual&btnG=Google+%E6%90%9C%E7%B4%A2&aq=f&oq=
choose second one PDF file and download for a while. then go to page 89.
hope help you to fix it , and please take a rating let me know how much helped you thanks!
May 16, 2009 | HP LaserJet 2420 Printer
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
HP LaserJet 2420 Printer Logo
2,545 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
