States that waste ink is near full - how do I correct this
It states that waste ink is near full and does not want to print or copy and if I press the set key like it says to do it still comes up with the same message. What do I do to correct this?
Re: States that waste ink is near full - how do I correct...
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
It is not recommend you try to fix it yourself, you can try to manually reset the error code, but if the waste ink is really nearly full and you reset it, it could damage the printer pretty severely. Here are manual reset instructions for a similar model printer, it should work on the F60 if the buttons are the same:
1) Enter Service mode by pressing: menu-copy-#
2) select: Test Mode
3) select [8] printer test in test mode
4) select 3 [eeprom clear]
5) select 0 [ink count]
6) press the [stop/reset] key (returning to the state of 3), and press the [on/off] key
If that doesn't work try this one:
1) Enter service mode by pressing MENU,COPY,SCAN,COPY,COPY
2) Select TEST MODE
3) Select (8) PRINTER TEST in TEST MODE
4) Select 3 (EEPROM CLEAR)
5) Select 0 (INK COUNT)
6) Press the SET key
7) Press the (Stop/Reset) key, returns to the state of 3, then press the ON/OFF key
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error) Solution: Press the <RESUME/CANCEL> button to clear the error (1700) Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible. Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error) Solution: Press the <RESUME/CANCEL> button to clear the error (1700) Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Hi
This works on the F30, F60, and F80. Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre to do the service job. The WASTE INK ABSORBER KIT is approx. USD10/pcs
I think this one will help you
Reset Waste Ink 1) Enter SERVICE MODE. By pressing Menu, Copy, Scan,Copy,Copy 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [Set] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
yeah try this.
