Question about GE Ovens
Advantium--removing lower halogen cover
Spilled food into lower halogen heating element, but can't remove glass cover because single screw holding it down is weird--not Philips or other usual screw type. Kind of star- shaped opening in head. Know how I can remove this screw?
  • H Pogo
    H Pogo Dec 31, 2013
    A torx driver was my first choice, but couldn't make it work. Just now I visited the Wikipedia page on torx and learned there is a tamper resistant model that has a pin in the middle to prevent driver from being inserted. So I need to get special driver for the tamper resistant screw. What a pain.
  • 4 Answers
You need a torx/star screwdriver
Posted on Dec 31, 2013
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Posted on Nov 25, 2007
SOURCE: Removal of outer door
Not sure if this has been covered - how to remove the door from the oven.
If you look at the hinges theres a pivoting piece (under all that grease) like a zippo lighter lid. Flid that open towards you and the oven door will pop out when pivoted closed - hinges and all. It should be fairly easy to put back too. Then follow the other instructions - screws on door base.
Posted on Sep 08, 2008
SOURCE: REMOVAL OF FAN
Ha - I found the solution myself. You need to remove the 3 screws securing the fan motor. Once you've done this, you can wiggle the fan a few mm, far enough to be able to remove the top element screw.
Posted on Jan 18, 2009
barkencoa
  • 3463 Answers
SOURCE: element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
  • 25 Answers
SOURCE: Replacement of fan oven element on Nef U1721
Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
Posted on Jun 25, 2009
Bread (biscuits/rolls) burn on top and raw on bottom.
there are two elements in the oven one on top..one on bottom...the top one is also used for broil functions...the lower element may have burned out...to remove it there will be a screw holding a plate with the lower element attached to it...you may also need to turn the oven around and in the back there may be a cover where the electrical connections are...you may need to unscreww 2 screws to remove the element...if you have a multitester or can get one ..you'll want to check the resistance of the element..it will be a low value(not sure what value exactly). If it won't give a reading or shows nothing on the meter then you'll need to replace the element...you can get elements at appliance parts stores or on the internet..you can even try an appliance repair shop for parts.
Dec 22, 2010 | Whirlpool RBS245PDS Electric Single Oven
Bake at low temp. Heating element vs control board
you need a meter that checks voltage (220) and continuity. turn off breaker remove screws that hold element in carefully pull it out just enuff to remove wires.remove wires check for continuity on element if there element is good. tape the leads to the wires turn on breaker, turn on oven if no 220 volts bad board or broken wire.
Feb 17, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Need to replace halogen bulb that illuminates Advantium interior
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Feb 17, 2009 | GE Profile Advantium SCB2001KSS Stainless...
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
WHIRLPOOL OVEN +G2P61F
Remove cover at rear of oven compartment, there you will see the element.
Undo fixing screw(s), carefully pull the element towards you, remove wires, be careful not to lose them inside ,and fit onto new element.
Refit element and rear cover.
Thanks.
Jan 18, 2009 | Amana AOCS3040SS Electric Single Oven
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
How to replace lower halogen light assembly, also, replacing turntable shaft
item 1474 is the turntable shaft and is GE # WB02X10624
You should be able to remove item 1476 and lift out the shaft to replace it..then reinstall item 1476 to lock it in place, Hope this helps ...
Sep 12, 2008 | GE SCA2001FSS Advantium Electric Single...
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
Whirlpool oven heating element
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Ovens Logo
79 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
