Question about Pentair MINIMAX NT TSI IGNITER
The heater will either not turn on or will turn off after 2 minutes
We are having a problem getting our heater to turn on. this morning it turned on, but shut down after a minute or two
    Problem Solver:
  • 11 Answers
Checkl the flame sensor current on the ignition module.
and make sure the limit s and pressure switchs are closing.
Posted on Jun 06, 2009
I went to take a shower this morning and the water was ice cold. For more than twenty minutes the water ran and never warmed up. Are there common things to check my hot water heater for in this situ
There is an adjustment knob to control how hot the water can become. There might be a problem at the tap (however, if this is the case, you would still get hot water everywhere in the house). If the entire house isn't getting hot water, and the knob is set at the hottest water, you probably need to get the hot water tank replaced.
Feb 04, 2015 | Rheem Tankless Hot Water Heater...
My 80-gallon water heater is underperforming.
1) Is this electric or gas water heater????
Look at label on side of tank for type, brand and serial number.
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
2) Copy following link for Electric water heater troubleshoot:
Turn up temperature, test for crossover, test dip tube, test lower element, etc
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#gradually
3) Copy following link to identify gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
4) Add a comment Dec 2012 with more detail, or for followup help as needed.
Dec 14, 2012 | American Standard Water Heaters
I have a 40 gal Whirlpool single element 3500 mobile home hot water heater. I have replaced the element thermostat high pressure valve (because it was leaking) & flushed for sediment. In morning I wash...
A 40 gal. electric water heater will give you aprox. 32 gal. of hot water in one setting, since they do not reheat as quickly as gas. So if you are using a newer 1.5 or 2.0 gpm shower head. You could take a 16 minute shower with straight hot water. If you are running 2 new shower heads at once you could get 8 minutes. If you using the tub spout the times decrease. Some of my customers like to turn up the temerature on the thermostat a little so they can mix more cold and get it to last a little longer. Be very careful doing this.
If your water heater has a lot of calcium built up in it the times will decrease.
With out seeing the heater, you mention it is a mobile home heater so I am guessing that it is bottom fed.
I hope this has helped.
May 09, 2010 | Water Heaters
Windows fog up on the inside when defroster is turned on
leaking heater core. The coolant level may be low also. What it is doing is fogging up the window with the steam coming from the hot engine coolant that runs through your dash board when the heater or defrost is on. This should be under some kind of warranty on an '08.
Dec 05, 2009 | 2008 Hyundai Sonata
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Seat Heaters in 2004 Yukon turn off after a few minutes
check your personal settings. my brothers did the same until he reset the personal settings
Feb 03, 2009 | 2004 GMC Envoy
A few Problems: Starting, Heater & Radio
Problem 1: buy a system heater to keep the engine warm at night.
You can buy them at any autoparts store . You take your pick from the variety.
Place a light 100 Watt Bulb near the battery but not too close to anything else where it might burn anything.
Problem 2. Check your coolant level to see if you have the proper level. Make sure you have 1/2 antifreeze and 1/2 water if you add any coolant /antifreeze and bleed the colant system. By running the car let it cool, then turn the radiator cap or turn the bleed screw provided on some cars near the thermostat outlet. Then adding some more water and coolant etc.The tightening the cap or bleed screw. When radiator is full. Check the radiator and and remove any debris that may be keeping the air out.
Problem 3. Will get fixed because your battery won't die.
Jan 11, 2009 | 2002 Jeep Liberty
Oil filled heater wont stay on
I was having the same problem and did a search to find this link. This morning when I turned it on, I backed the temperature down to 66 when it first came on (defaults to 70) and it appears to be working now (it's been on for over 10 minutes)
Mar 17, 2008 | Honeywell HZ-710 Oil Filled Radiator...
Pentair MINIMAX NT TSI IGNITER Logo
345 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
