Vcr repair manual
Vcr comes on will not stay on motor shuts down
  • Televison & ... Master
  • 5,391 Answers
VCR's shut down when the mechanism is jammed up and won't move. Taking the top cover off might reveal the damage. Since you don't say what the make or model is I can't say much more or say where to get a service manual.
Posted on Jan 04, 2014
How do i cancel f-1 on my jvc vcr
F1 is a fault code. When the unit initialises, it spins motors and self tests. If it detects a fault it displays F1 and shuts down operations.
Needs to go to a service centre for repair, sorry.
Aug 01, 2012 | JVC Televison & Video
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
TV shuts off after 5 seconds Magnavox CT270MW8
Open TV and notice if the VCR cartridge jumps (jitters) back and forth when you plug the TV in before it shuts down. If it does, there is a good chance you will have to replace the VCR mech on this unit (available from Andrews Electronics and maybe MCM electronics for $40-$50). This is a common problem on this unit. I work in a TV repair shop and see a lot of these come in for this reason.
Sep 28, 2009 | Televison & Video
May Magnavox MWC24T5B tv/vcr/dvd combo will not stay on.
I've found the center LED in the VHS player faulty with those symptoms. Change it you'll be fine. Larry
Jun 17, 2009 | Philips Televison & Video
Dvd/vcr
well sounds like one of the players is not in correct spot thus shuts down (kinda timing issue) see if there is anything preventing it from going jiggle or turn upside down see if you hear anything.
Feb 12, 2008 | Philips Magnavox DVD/VCR Dual Player
TV wont stay on
The vcr carriage was probably damaged ( broken gear or carriage gear, etc ), As for repairing it, it may not be worth it and chances are, you won't find a new carriage for the unit. I have, in the past, disarmed the VCR unit and at least the customer could watch the TV. Thats not possible in every set, but it seems to work in the majority of them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 22, 2007 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
RCA RT2250 consistant shutting off in Satalite mode.
Mine will always just turn off every minute or so after a hard shut down(ex: power outtage). I have to turn it back on and then hold the set button for a few seconds, then it stays on, until i turn it off manually, since the remote won't turn it off.
May 15, 2007 | RCA RT2250 System
VCR automatically goes into standby mode
If this unit shuts down after you turn it on, it is going into stanby because the microprocessor is not seeing the proper pulses from the mode switch. this could be due to an out of time mechanism because of a broken gear, bad mode switch, the loading basket is out of time or broken, or the capstain motor or the cylinlinder motor is not sending the PG and FG pulses to the microprocessor. These can also be due to a power supply voltage missing. You can check the voltages with a service manual and make sure they are not low. You will also need to get the mechanism manual and check the timing of the mechanism. Then check the mode switch you can get a manual from here http://www.servicemanuals.net/results.aspx?brand=15&model=HRS&type=SM&pos=281 Good Luck
Mar 21, 2007 | JVC HR-S9900 S-VHS VCR
In RCA T13208 13 in. TV/VCR Combo shut down after turn it on
The safety circuit is sensing a problem and is why it will not let the tv stay on,the cause could be a problem on the mechanics of the vcr,you need to get an estimate to see if it is worth the repair and might be able to keep using just the tv.
Sep 23, 2006 | RCA T13208 13 in. TV/VCR Combo
TV shuts off after 10 sec
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Sep 16, 2006 | Samsung CXD2512 25 in. Combo
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
