Question about Asko W6661 Front Load Washer
Now getting a water outlet fault - Asko W6661 Front Load Washer
  • Asko Master
  • 5,323 Answers
TEST WITH MULTI METER FOR OHMS
Posted on Apr 03, 2015
Trying to descale Miele coffee system-- keep getting alternating faults --10 or 17.
These codes relate to a water supply problem. If this is a plumbed system then check the water is turned on and hoses are not kinked. There is also a valve at the bottom of the water container outlet that may be clogged. Other than this its an internal fault with flow meter or coffee/hot water pump. Regards
Apr 16, 2017 | Miele Coffee Makers & Espresso Machines
The water from the supply tube which supplies water to the icemaker freezes. Which is faulty - the icemaker or the water valve?
If the water is freezing in the supply tube then its not water valve or icemaker fault.Its the fault of defrost board.Its not letting the unit to defrost on time and this is causing the problem.If water is faulty then water will over flow or no water will flow,if ice maker is faulty then it will not make ice.Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Feb 01, 2011 | Jenn-Air JCD2389G Side by Side...
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jan 04, 2011 | Washing Machines
Refrigerator has electrical short causing GCI outlet breaker to pop. Is this an easy or cost prohibitive fix?
It is possible you have a short. However, the more likely cause is the simple fact the refrigerator is plugged into the GFI outlet. Try this first, take a heavy duty three prong extension cord, NOT a lamp extension cord, plug it into a non GFI outlet, and plug the fridge into the cord. Does it trip your house circuit breaker? If so, then you do have a short. You will need to call a local refrigerator repair company to find the source of the short, and only then will you know if its an easy or cost prohibitive fix. If it does not, and it likely wont, the problem is that a GFI outlet detects a fault to ground. Due to the humidity and moisture inside a refrigerator, and normal water drainage sometimes into the metal base of the refrigerator, it is not uncommon for water to contact metal points inside and outside a refrigerator. Since all / most metal points on a refrigerator are grounded to each other, if water contacts any of them, they can and will trip a GFI outlet breaker, because it is detecting a fault to ground.
Nov 09, 2010 | GALAXY Microsystems 63702 Top Freezer...
What can I check on or do when getting a water
check the filter basket that catches waste from the washup. Also follow the outlet hose ( usually winds through cupboards to the sink outlet. ) and see there are no kinks in it from articles being pushed against it.
If these are OK it may be that ther outet valve is jammed and this will require a tech, as the whole casing will need removing
Please rate my help++++Thankis for using FIXYA
May 15, 2010 | Asko W6641 Front Load Washer
Water not coming out of machine
If water is in machine and not pumping out there could be a blockage in the outlet pipe or pump. If you can not hear the humm of the pump then there may be a pump fault. Possibly just a blokage in the outlet pipe though.
Feb 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Asko W640 water outlet fault
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
Sep 11, 2008 | Asko W640
Waterproof fault
I just received this error message on my Miele WPS 4146 (Waterproof Fault) Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
So here is the fix that worked for me.
2. Unplug it
Jun 19, 2008 | Miele Washing Machines
W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Apr 09, 2008 | Asko W640
Asko W6661 Front Load Washer Logo
61 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
