Question about Xerox Phaser 8550DP Printer
Installation of Phaser 8550 DP on network
I want to install a Xerox Phaser 8550DP Printer on my network. The server is Windows 2008 and I want to be able to print from windows workstations with XP and from a Mac OS X.
This is no problem for someone with even a little networking knowledge, but it would take longer to write the instructions here, than it would to have someone spend less than an hour configuring it on site. That's my recommendation
Posted on May 20, 2009
Xerox 8550 error code 19,004,40
19,004.40: The printhead and the electronics module do not match. Contact escalated Service Support Representative for information to clear fault.
May 31, 2010 | Xerox Phaser 8550DP Printer
I have moved my xerox phaser 8550 from one room to another. it wont power up, i have checked connections and cables. also the ink waste tray has got jammed. could this be related . help
you should see power indicator when you turn it on but the printer will still not work if it has jammed paper, check also the walloutlet maybe it has no power or connections are loose
Oct 19, 2009 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550 Maintenace Kit is stuck in the
If you remove the right side cover, you can operate the process drive gearbox with a straight-blade screwdriver on the end of the shaft (bottom of printer right in front of maintenance kit). This is the end of the drum maintenance camshaft. Rotate clockwise slowly. It's possible that the cams have cracked and rotated on the shaft. This is the weak point on these printers. If so, they may not be in sync. Good luck.
Jul 13, 2009 | Xerox Phaser 8550DP Printer
Phaser 8550 . what does printer error code 09,005.40:78005 mean?
9,0XX.xx Errors - Ink Loader Faults. Try switching the ink loader.
Jul 08, 2009 | Xerox Phaser 8550/DP Thermal Printer
I'm looking for instructions to install the control panel for a Phaser 8550 DP.
Xerox has a video on how to install the control panel at:
http://www.office.xerox.com/userdoc/P8500_8550/8500_8550_Web/videos/controlpanel_installation.html
May 28, 2009 | Xerox Phaser 8550DP Printer
Xerox phaser 8550 error 37,004.40:158510
most likely problem, is that your printer is not getting enough power, verify that there are no external power supplies, or extention cords connected to the unit, also, you might want to try another power plug.
thanks
Apr 17, 2009 | Xerox Phaser 8550DP Printer
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Mar 31, 2009 | Xerox Phaser 8550DP Printer
Phaser 8550 printer fault 37,008.44:25860
This is a pre heater error.
I would make sure the printer is connected directly into the wall and not into a power strip or UPC as these devices may create momentary AC voltage sags that could cause this error. If power levels going into the printer are good, you will need to contact Xerox for support
Jan 13, 2009 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP Printer does not recognize the ink it has
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes.
Nov 16, 2007 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP Printer Logo
143 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
