Question about dayton 2yny3 replacement latch clevis slip,5/8in
Need to oil the 3k515 pump, where at? How many places?
Replacing oil pump on Husqvarna 257
The oil pump is behind the clutch. You will see 3 bolts holding the pump in place. Some pumps must use the M5 screws in the 180 degree extractor holes. There is also 2 screwdriver slots you can use to pry out the pump is needed. If the pump lifts out, you are good to go.
May 23, 2014 | Husqvarna Garden
2001 chevy silverado /170000 plus mileson when i went to pull out briskly the motor started tapping and lost constant oil pressure when it is idling the oil pressure goes down to almost zero and the op...
Sounds like your oil pump is "getting tired". If you plan on keeping it for any length of time, you're probably going to have to replace oil pump. To replace you'll need to drain oil, drop oil pan and you'll find oil pump and pick up tube and strainer bolted to lower part of engine. Unbolt, slide out holding oil pump shaft in engine, slide new pump/strainer and pickup in place, bolt in place, reinstall pan and refill with oil.
Feb 23, 2011 | 2001 Chevrolet Silverado 1500
My 3406b caterpillar engine is having excessively high oil levels
HI,
Time to find out why your oil level is going up.
Either coolant in the oil, or fuel in the oil.
Which ever it is the cat engine is not happy. My suggestion would be to get an oil sample test.
Any major diesel repair place will help. Just a little oil in a sterile jar to be analyzed for contaminants.
Coolant is the worst as it will scour the bearings.
Good thing you are concerned.
Wayne
Dec 02, 2010 | Ford F-450 Cars & Trucks
Oil pump ,,,where is the oil pump located on a 1997 dodge caravan
Hello
Welcome!
Oil pump is located on the oil pan.
Parts needed,,,oil,,,, oil filter,,,, oil pan gasket,,, oil pump,,,, oil pump pickup tube..
time to do this,, about 3 hours
Instructions,
Raise van place on 2 jack stands
drain oil remove oil filter fill new filter install.
remove bolts from oil pan,
remove oil pan..
remove 2 bolts that hold oil pump and tube.
install new pump and tube tork bolts to 45 fp
replace oil pan gasket and install oil pan
tork pan bolts to 35" pounds
install drain plug
fill with oil
start and check for leaks
let me know if i can help more
Jul 17, 2010 | 1997 Dodge Caravan
Where is the oil pump located on a 1999 ford taurus and whats items do i need replace a long with the oil pump
Remove oil pan oil pump and pick up tube & screen will be bolted on.
You should get oil pump lube, carb. cleaner, new pump oil,
oil pan gasket, silicon, oil & filter, loc-tight, gasket remover & tools metric, 1/4 drive socket set, scraper / putty knife, 2 jack stands, a jack or ramps,
& blocks for rear wheels.
Lets get started.
(1)Get your car up on stands or ramps block rear tires.
(2)Drain oil & remove oil filter remove battery cable NEG (-)
(3)remove pan
(4)remove old pump
(5)remove pick up tube from oil pump
(6)Now clean tube & screen with carb. cleaner place on news paper to dry.
(7) clean all old gasket off from engine & pan also clean bolts
(8)place silicon on pan place gasket on pan put bolts in from gasket side to Aline holes put a side to dry
(9) Attach tube to pump with a little loc-tight fill pump with oil pump lube
(10)attach pump to engine block make sure rod goes in proper & bolt are tight.
(11)Bolt pan back on engine using a 1/4 in drive ratchet don't over tighten bolts get all bolts in now slow run each bolt in starting at 1 end then jump to the other then go to bolt at other end a cross from 1st bolt. Do this till all bolts are ran in. Now tighten bolts look for gasket on side of pan.If it starts to push out stop go to next bolt.
(12)Instill new filter & drain plug,& pour in oil
(13)Replace Neg - cable
I hope this works for you it's a basic oil pump change for most cars.
Some take more steps.
Jul 14, 2010 | 1999 Ford Taurus
How do you change a oil pump
This is straight from the book.
1. Remove oil pan.
2. Place large drain pan under engine
3. Unbolt the pump and exstension shaft from the rear main cap.
4. Lower same
5.Before reinstall prime the pump with engine oil. Pour oil in the exstension shaft while turning the pump.
6. Attach the pump, extension shaft and retainer to the main bearing cap.
(aling the pump with the dowel pins while you align the top end of the exstension shaft with the lower end of the oil pump drive.
Note when proper it fits into place easily.
7. install the pump mounting bolt and torque to spec.
8. Put the oil pan back on.
Jan 28, 2010 | 1997 Pontiac Sunfire
I dont know where the oil pump is on my 89 toyota
On a 22RE the oil pump is on the timing cover behind the crank pulley/harmonic balancer,it has the crank timing pointer built onto it,generally they don't leak around the pump seal but as Monster80 pointed out they leak from the front main seal wich is installed on the front of the oil pump,pretty common for the 22R/RE to leak around the timing cover gaskets or out the bolt holes on the timing cover also,usually due to uneven tourqe on the bolts,to check the front main seal you need to look at the the crank from the underside right after you've shut the motor down,if the seals bad you'll see oil starting to form a drop on the backside of the pulley or the front of the oil pump housing.
Apr 03, 2009 | 1986 Toyota Pickup 4WD
Power steering pump replacement for Subaru Outback
REMOVAL
  1. Remove ground terminal from battery.
  2. Remove pulley belt cover bracket.
  1. Loosen lock bolt and slider bolt and remove power steering pump drive V-belt.
  2. Disconnect connector from power steering pump switch.
  1. Disconnect pipe C and suction hose from oil pump. CAUTION:
    • Do not allow fluid from the hose end to come into contact with pulley belt.
    • To prevent foreign matter from entering the hose and pipe, cover the open ends of them with a clean cloth.
  1. Remove bolts which install power steering pump bracket.
  1. Place oil pump bracket in a vise, remove two bolts from the front side of oil pump. CAUTION: Do not place oil pump bracket directly in the vise; use soft pads and hold oil pump lightly to protect the pump.
  1. Remove socket from oil pump.
  2. Remove bolt from the rear side of oil pump.
Jan 18, 2009 | 2002 Subaru Outback
Chevy Blazer 1992 Oil Pump Change
you have to drop the oil pan to get to it...once the oil pan is off there are 2 bolts that holdthe pump in place,,,you will also need a new screen for the new pump.
Jan 03, 2009 | 1999 Chevrolet Blazer
dayton 2yny3 replacement latch clevis slip,5/8in Logo
Top Dayton Wire Wheels Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Dayton Wire Wheels Vehicle Part and Accessory Expert? Answer questions, earn points and help others
