Question about Dell Inspirion One 2320 IO2320-5555BK All-In-One PC - Intel Core i5-24
Loading drmk v8.00 - Dell Inspirion One 2320 IO2320-5555BK All-In-One PC - Intel Core i5-24
Pxe-61 media test failure.check cable pxe-mof: existing pxe rom.loading drmk v8.00
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If your CMOS Setup has an option to boot from the LAN disable this option.
If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Then try re-booting and tapping the f12 key which should start up a diagnostics page
Mar 06, 2014 | Dell Vostro 3700 Laptop Computer PC...
Hi - hoping someone can help, Have recently purchased a Dell Inspiron N5110 which booted windows fine the first time I switched it on, set up all worked and seemed to be fine. Now when I try to start up...
Hello!
How long ago and from where did you purchase this device?
Suggested solution:
If within time limitations set by seller, return item as D.O.A.
and demand an immediate replacement. It's the MORALLY correct thing to do...
Nov 23, 2012 | Dell Inspiron 14r N4110 2.00ghz B940 4gb...
Loading drmk v8.00 is shown when F8 is pressed before booting
This sounds like a resealing issue. Was this computer reimaged recently? If it were, I would simply reimage again...it looks like the job didin't finish completely.
Nov 23, 2012 | Computers & Internet
Sata Hard drive errors and Raid errors
See this answer
Reboot your system and hit F2 as soon as you see the Dell startup screen (the options are F2 for setup, F12 for boot sequence).
In the System Setup screen, do these steps.
Select Drives:
Make sure your Diskette Drive (3.5 floppy) is set properly (Usually set to Internal)
Make sure that "Drive 0: SATA-0" drive is set to "ON"
Go to "SATA Operation":
Your system proabaly came set to "RAID Autodetect / AHCI" - THIS SETTING CAUSES YOUR SYSTEM TO GO INTO AN IDE LOOP AND DOESN'T ALLOW IT TO FIND YOUR FACTORY INSTALLED SATA DRIVE.
CHANGE THE SATA OPERATION SETTING TO "COMBINATION"
Reboot - make sure that the boot sequence is set to CD rom before HD and make sure that the reinstall CD is in the drive. Setup will load, hit enter to reinstall XP. Your HD should now be detected and you should see the licensing agreement.
If you have your files backed up I reccommend deleting the partition and reformatting prior to installing XP, it will give you that option after the license agreement.
Once you have successfully reinstalled the OS, Dell reccommends that you change the SATA Operation setting back to RAID AUTODETECT / AHCI (or back to whatever your factory setting was) to avoid any problems with other IDE devices installed on your system.
Source
Restore Complete but Stuck on DRMK
Sep 03, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I entered my restore disk after receiving message on hard drive on the dimension 9150. Got message
Hmmm, what concerns me is that your system BIOS is not discovering any of your SATA Drives, That sounds like an Issue in your motherboard not your OS. I would go into your BIOS settings and look for a link that says reset bios to factory defaults, then try and boot again without the recovery disk. Please keep me posted on what happened if this does not we will trouble shoot more.
Dell laptop crashed
reset bios setting & select 1st boot hard disc.
May 30, 2012 | Dell Inspiron 5100 Notebook
Which washing machine is better front load or top load?
Front load washing machines are better than top load money wise.
One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
05 R1 front wheel
A new wheel is going to cost $$$$. You should be able to get a good used wheel for $$ by getting on the web and Google
' motorcycle salvage yamaha '. Take three digital photos of your wheel, a side view both sides and a close up of the brake mount area. When you locate a dealer saying they have the wheel, email the photos and your contact info. If their wheel matches up, go for it.
Please rate this answer Thanks Andy!
Mar 29, 2009 | 2005 Yamaha YZF-R1
Kstvtune.ax
ALCXWDM.SYS
portcls.sys
ksxbar.ax
kswdmcap.ax
vidcap.ax
vfwwdm32.dll
CCDECODE.sys
NABTSFEC.sys
WSTCODEC.SYS
ipsink.ax
MSTEE.sys
isapnp.sys
usbuhci.sys
usbuhci.sys
stream.sys
wdmaud.drv
ks.sys
ksproxy.ax
drmk.sys
ksuser.dll
I can't install my multimedia as these files are missing. I tried reinstalling the drivers but it needed these files which I can't download even after I have inserted the Windows XP Cd. Can you please help me with this also let me know how I can download these files from the net.
Jun 02, 2008 | Microsoft Windows XP Professional With...
Dell Inspirion One 2320 IO2320-5555BK All-In-One PC - Intel Core i5-24 Logo
mukhtar21 shaikh
mukhtar21 shaikh
