Question about Dell Office Equipment & Supplies
Dell 2335dn scanning problem "updating Data - please wait"
My scanner just suddenly stopped scanning. It pulls one page thru and starts the second page and stops. It says in the window "Updating Data Please Wait" then it moves from the scanner mode to the copy mode and nothing happens. What does this error mean?
  • 3 Answers
Canon lbp600
Posted on Dec 31, 2013
welcomejee
  • 10594 Answers
SOURCE: cannon pixma 780
is your printer under warranty? If yes, ask warranty cover please.
Posted on Sep 24, 2008
jtuminaro
  • 56 Answers
SOURCE: My MFC 8860DN does not scan or copy but instead says please wait
Turn the machine off and hold menu while turning it on and keep holding it while the machine starts up. This should go into maint mode.
When it gets into maint mode you can try 99 to exit. This is like a soft reset. Hard reset is hitting 01 in maint mode and then 99 to exit.
Let me know if this is helpful.
Posted on Jan 15, 2009
SOURCE: Scanning problem with A940 AIO Dell printer/scanner
    Hi there, just found this solution to work perfectly. i just freaked out for a moment with the same problem. Use this or just type fax and scan in your help function. Hope this helps!
    Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
  1. Windows Photo Gallery.
  2. Click File, and then click Import from Camera or Scanner.
  3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
  4. In the New Scan dialog box, click the Profile list, and then click Photo. The default settings for scanning a picture are automatically displayed.
  5. If you're using a scanner with a document feeder, click the Paper size list, and then click the size of the picture that you've placed on the scanner or click the size that most closely matches the picture.
  6. Click the Color format list, and then click the color format that you want the scanned file to display.
  7. Click the File type list, and then click the file type that you want to use to save the scanned file.
  8. Click the Resolution (DPI) list, and then click the resolution, in dots per inch, that you want to use.
  9. Adjust the brightness and contrast settings or type the values that you want to use.
  10. To see how the picture will appear when it is scanned, click Preview. If needed, modify the scan settings, and then preview the picture again. Repeat these steps until you're satisfied with the preview results. Some scanners might require you to place the picture in the document feeder each time that you scan.
  11. Click Scan. When the scan is complete, Windows Photo Gallery prompts you to tag the picture so that it's easier to organize or find later.
  12. In the Tag these pictures (optional) list, type a tag name, and then click Import. Windows Photo Gallery displays the picture so you can view, fix, or organize it.
Posted on Feb 06, 2009
SOURCE: My HP Deskjet F2120 All-in-one Printer Scanner
I've got the same problem.
Posted on May 14, 2010
SOURCE: Dell 964 scanner
First do your scan on Dell 964 scanner &printer. Scan to clipborad. You hear it scan but nothing happens on your computer. Go to control panel - scanners and cameras - scan profiles - find the document you have scanned, select it and click edit - click preview - in the left corner you will see in blue "How to scan a picture" click that, it will lead you to Windows Photo Gallery - there click on file and import from scanner of camera - it will scan there and your scanned pics will be in your picture folder :) Took me a while to figure it out :)
You can avoid all this and go directly to Windows Photo Gallery :)
Posted on Jan 05, 2011
My fujitsue fi-6130 stopped automatically scanning both sides
You can try a 'hard reboot' of the unit by unplugging it while it is running, wait a minute or so and then restore the power.
With most electronics this forces a 'self-diagnostic' program which might fix the problem. Another option is to delete and them reinstall the software with a disc or online. Make certain that you have your machine set to automatically check for updates if it is connected to the Internet.
Jul 22, 2014 | Fujitsu fi-6130 Flatbed Scanner
How can I remove the flatbed from a dell 2335dn
Unplug it and wait 5 minutes. Then slide the blue lock from locked position to unlocked position, it shoud move fairly freely. Then plug it back in and you should be good to go.
Jul 26, 2012 | Dell 2335dn Multifunction Laser Printer
I want to scan documents from the printer to a memory stick, how do I do it?
you should go thru the main menu on your computer screen (assuming the printer is hooked upto your PC).
I have never had an issue with it going this route.
Oct 18, 2011 | Dell 2335dn Multifunction Laser Printer
The network computer finds the dell2335dn and the printer/scanner finds the computer, but when i try to scan to the computer it tries connecting and fails....please help
I would suggest deleting the printer and then re-adding it. If you do not have the original CD, then go to Dell to find the drivers.
Apr 01, 2011 | Dell 2335dn Multifunction Laser Printer
I have a Dell 2335dn. We scan paperwork to our flash drive to transfer to other locations. We put the flash drive in the front of the scanner and then our paperwork, but now it is saying to insert the...
I have the same printer and have been scanning documents and pictures for several years and this just started as well with two seperate flash drives at the same time...please help.
Feb 12, 2011 | Dell 2335dn Multifunction Laser Printer
How do I unlock the scanner on a dell laser MFP 1815 dn printer. I can't fax or copy anything. It says the scanner is locked.
There's a little blue toggle switch where the copies/scans come out from.
Pull the blue switch toward you, turn off the printer, wait a few seconds, and turn the printer back on.
Aug 27, 2010 | Dell Printers:Dell MFP Laser Printer...
Scanner stopped functioning
r u already try reinstall your driver?if not, try it 1st and see the result..i'm afraid the driver is damages....try to download from canon support website in order to get the updated one...hopes it will help ; )
May 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Dell 922 printer all in one
I have a Dell 942, and I also ran into problems scanning. Basically, the Dell "All In One Center" refused to open, and when the printer generates a scan, it tries to send it to that application. What worked for me was uninstalling Microsoft Internet Explorer 7 and 8. Once I was back to IE6, my Dell printer functioned normally. Upgrading to IE7 immediately "broke" it again.
I discovered this after running a repair installation of Windows (a recommended action any time you start experiencing weird problems). I did not have to format my hard drive or lose any data, although some applications had to be reinstalled or re-patched afterward. But the repair install took me back to IE6, and magically, my printer suddenly worked again! When I went to the Microsoft Update site and upgraded to IE7, poof! Dell AIO Center would no longer open, and I couldn't scan.
If this solution is helpful to you, please rate it.
Thank you,
~~Cheryl
Aug 30, 2008 | Dell 922 All-In-One InkJet Printer
DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
Jun 22, 2008 | Canon DR-9080C Path-Through Scanner
125 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
Jerry Umali
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
