Question about Frigidaire GLGQ2152ES Gas Dryer
Frigidaire Dryer only runs on "low Heat" setting
I have a Frigidaire dryer model number GLGQ2152ES0 that started having troubles a month ago, showing a "DR" error code. Technician came several times and repaired motor, changed thermistor and finally decided to change the control board (expensive). The board he installed has a different part number (original part number 134523200, new board number: 134345100, which I don't find on internet).
Now the dryer only works on "low heat" settings. For all other settings, nothing starts and the error "DR" appears. Should I change (once again) the control board? Can it be something else?
I've already spent lots of money on this, I'd like to stop the bleeding... thanks
  • Anonymous May 20, 2009
    ?? How is this supposed to help me?? Other than showing our slight inclination for racism, it's of no help
  • Frigidaire Master
  • 8,220 Answers
Mexitronics
Posted on May 20, 2009
E 64 code on a Frigidaire affinity dryer, but still getting heat. What could be the problem?
that has three sets of coils in it,one of them is bad this is most likely why you still have heat,i've seen it a few times,change out the heater box,go here and look at the last picture,you'll see the three sets of coils one of them is broken,just order your heater box for your model number off of your dryer.change out the heater box
https://www.appliancezone.net/134792700-frigidaire-dryer-heating-element-replacement/?gclid=Cj0KCQiAvrfSBRC2ARIsAFumcm_UzfGwntvtSVc9IDruzrS145S-0pcaF2W7iBwEOgT2y1r4boAgEPAaAoi4EALw_wcB
Jan 04, 2018 | Frigidaire Dryers
I have a Frigidaire dryer that has no heat only has heat on Gross low heat cycle but goes off and on
it should go off and on the heat doesn't stay on all the time,also what's the model number,
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
MY DRYER DONT START,she make a sound but not start
Hello Friend, thank you for allowing me to assist you!
I understand you are having trouble with your Frigidaire dryer not starting. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, then at this point, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. You dryer may either be experiencing a communication error with the main control or the timer itself may not be operating correctly. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
May 24, 2014 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Quentin
Aug 21, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Gas dryer not heating
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 22, 2009 | Frigidaire Dryers
The dryer does not heat.
If the dryer runs but does not heat, then there are many reasons why this may happen.
Remove the vent line from the rear of the dryer and see if it gets hot. if so you need to unclog the vent line.
If it does not then you have a bad thermostat .
Apr 03, 2009 | Dryers
Frigidaire GLGQ2152ES Gas Dryer Logo
986 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
