Question about GMC 2003 Envoy XL SLT
Replace ac/heater control switch
How do I remove ac/heater control switch and replace it with a new one.
  • GMC Master
  • 10,291 Answers
Not enough information... what kind of car and where on the dash is the switch located?
Posted on Jan 02, 2014
I have replasteb the heater/ac blowermoter and restester checked the bender door working and the ac/heater is still not working Why isn't it working????
What exactly isn't working? the blower motor? If so then you may need a new blower motor harness from the switch to the blower, the connector burn up (under sized wiring) at the dash control head, you will also need a new blower speed control switch.
Sep 26, 2016 | 1999 Chevrolet Silverado 1500
1992 323 mazda want blow heat out
REPLACE THERMOSTAT.IF ALREADY DONE.CHECK HEATER BLOWER MOTOR SEE IF POWER GOING TO HEATER BLOWER MOTOR.IF YES BLOWER MOTOR BAD.IF NO POWER GOING TO BLOWER MOTOR CHECK AC AND HEATER CONTROL FUSE AND CHECK BLOWER MOTOR FUSE AND RELAY IF ALL IS GOOD CHECK SEE IF POWER GOING TO AC AND HEATER CONTROL SWITCH IF YES THE AC AND HEATER CONTROL SWITCH COULD BE BAD.
Nov 10, 2011 | 1991 Mazda 323
My 97 buick lesabre limited heater/ac blower quit, it has the climate control,I checked all fuses.
REMOVE HEATER BLOWER MOTOR HOT WIRE BLOWER MOTOR IT.IF IT WORKS.YOUR AC AND HEATER CONTROL SWITCH IS FAULTY.CHECK HVAC FUSES AND CHECK BLOWER MOTOR RELAY.IF BLOWER MOTOR DONT WORK WHEN HOT WIRE REPLACE IT.IF ALL CHECK OUT GOOD.HAVE DEALERSHIP DO A DIAGNOSTIC TEST ON YOUR CLIMATE CONTROL SYSTEM.
Dec 02, 2010 | 1997 Buick LeSabre
I have just replaced my thermostat housing bleed the radiator and i still got no heating the thermostat is brand new
MAKE SURE BLOWER MOTOR OPERATING IF NOT CHECK FUSE AND RELAY.ALSO CHECK HVAC FUSE THIS CONTROL HEATER + AC CONTROL SWITCH AND MODE SELECTION FOR OPENING AND CLOSING HEATER DOOR OR HEATER CONTROL VALVE AND AC+ DEFROST AIR DOOR.IF BLOWER AND HVAC FUSE OKAY.IF YOU HAVE MANUAL HEAT CONTROL MAKE SURE MODE SWITCH IS RECEIVING VACUUM. YOU HAVE TO REMOVE HEATER CONTROL SWITCH AND CHECK TO SEE IF GETTING VACUUM GETTING TO SWITCH LOOK FOR BROKE DISCONNECTED VACUUM LINES IN THE DASH AREA.IF YOU HAVE CLIMATE CONTROL.YOU COULD HAVE A FAULTY ELECTRICAL HEAT DOOR ACTUATOR.SOME CLIMATE CONTROL CARS HAS THE CLIMATE CONTROL PROGRAMMER HAS TO BE REPROGRAM BEFORE THE HEATER AND AC WILL WORK AGAIN.YOU NEED A DEALERSHIP SCANNER TO CHECK IT OUT.BUT IF YOU HAVE MANUAL CONTROL CHECK TO SEE IF YOU GETTING VACUUM.IF YOU GETTING VACUUM AT HEATER DOOR VACUUM ACTUATOR OR HEATER CONTROL VALVE EITHER ONE OF THOSE COMPONENTS COULD BE FAULTY.WARNING YOUR VECHICLE HAS AIRBAGS YOU HAVE TO DISARM THEM BY REMOVING FUSES WAIT 20 MINUTES BEFORE WORKING ON DASH AREA.YOU HAVE TO CRANK CAR UP TO CHECK TO SEE IF YOUR HVAC GETTING VACUUM.
Oct 24, 2010 | Renault Sport Cars & Trucks
Need to replace a fan relay switch. AC/Heater is
Just buy a new one, remove and disconnect the old one and reinstall.
May 26, 2010 | 2005 Dodge Neon
THE AC WONT BLOW OR THE HEATER
CHECK BLOWER MOTOR FUSE AND RELAY.IF BOTH GOOD.REMOVE BLOWER MOTOR HOTWIRE IT.IF DONT WORK REPLACE BLOWER MOTOR.IF BLOWER MOTOR WORKS.HEATER AND AC CONTROL SWITCH IS BAD.
Apr 30, 2010 | 2005 Chevrolet TrailBlazer
AC/Heater control valve :Lancer 2003 Misubishi
The sliding switch on the console is stuck in the cold position and the knob is pulled off. Use pliers to jiggle the switch as best you can. Feel under the center console and you probably will find the cable that is hooked up to the flapper. You'll know because when you jiggle the cold/heater switch at the upper console, the cable will move slightly. At the hookup of the cable to the flapper down under the console (passenger side) try to work the flapper loose to the open (or close) position. At the same time work the sliding switch (with pliers). The flapper will come loose and function properly. Try not to knock of the AC button like I did in the process. It flew off some where under the passenger seat. I'll find it sometime before summer. Ha.
Apr 21, 2010 | 2003 Mitsubishi Lancer
How to remove fan switch on 1999 oldsmobile alero or replace switch
FIRST OF ALL YOU NEED TO DISABLE AIR BAGS.TURN OFF RADIO FIRST SO YOU WONT LOSE RADIO PLAYING CODE.DISCONNECT NEGATIVE BATTERY CABLE. WAIT 15 TO 20 MINUTES UNTIL AIR BAGS DISCHARGE.TO REMOVE HEATER AND AC CONTROL SWITCH.YOU NEED A FLAT TRIM TOOL USE TO PRY UP TRIM AROUND CONTROL SWITCH.SO YOU CAN REMOVE CONTROL SWITCH SCREWS AND REMOVE CONTROL SWITCH.
Feb 26, 2010 | 1999 Oldsmobile Alero
Front heater fan control switch gets hot and melts. Why?
this is an easy one, the blower motor is drawing to much current, this happens as they wear out, replace the blower motor aNd all will be well in chevy land.
Feb 10, 2009 | 1997 Chevrolet Suburban
How can i remove and replace the heater/ac flow controller on my 03 elantra?
are u convinced it is a controller issue as this is rare on that vehicale i am more tempted to say that it is a cable problem. Or a door acuator if it is auto temp control
Sep 28, 2008 | Hyundai Motor 2003 Elantra
GMC 2003 Envoy XL SLT Logo
Top GMC Heating & Cooling Experts
gbob59
Lawrence Oravetz
Nicola Conroy
Are you a GMC Heating and Cooling Expert? Answer questions, earn points and help others
