Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Motor runs fine bu sometimes wont move
1999 Polaris 340 lite motor runs fine rpms no problem but sometimes it wont move.if you pick the back end up track moves fine. set it down and it wont move...sometmes
  • 451 Answers
It could be the belt is worn too thin and the clutch won't engage. Try a new belt and see if that solves the problem. Hope this helps.
Posted on Dec 31, 2013
3 Suggested Answers
dj_relly999
  • 4070 Answers
SOURCE: I have a 1999 Polaris XCR 700 it runs fine until
Hi and welcome to FixYa!
If that's the case then you may have a worn or loose vacuum hose somewhere. If there's a vacuum leak it can weaken the engine. Please try to observe the vacuum hoses if it has leakage.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Dec 15, 2010
  • 46 Answers
SOURCE: have 96 indy 500 want to know what would cause the
IT COULD BE A NUMEBER OF THINGS, I WOULD CHECK YOUR DIVE SHAFT AND JACK SHAFT BEARINGS, THAN YOUR CLUTCHES FOR WORN PARTS. IF THAT IS OK CHECK YOUR CHAIN AND SPROKETS. THAN DO A COMPRESSION TEST ON YOUR ENGINE.
Posted on Jan 06, 2011
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Polaris 570 started this morning fine .now it turns over but wont start .gas is full ,battery is full charge .
when you moved make sure you did not hit the kill switch that will not allow a spark .. the other thing you can try is to see if there is a spark. you can pick up a spark tester at any auto store
Feb 28, 2015 | Polaris 2014 Sportsman 570 EFI
My polaris booster pump just gets hot and wont run
the motor is bad overheating need a new booster pump
Sep 08, 2014 | Polaris Pb460 Polaris Booster Pump...
Polaris troubleshoot
If I was a betting man, you should do a compression Test on your Engine. What you are going to find is the PTO Cylinder has a lower compression than the Cylinder on the Right. Doing a Top End Repair on your Sled will only take 4 hours to do correctly. You can do RINGS ONLY but you may want to replace the Piston if the SKIRT has marred the Cylinder Walls to ensure a longer life. It is also recommended that you make sure your Oil Injectors are not clogged and functioning correctly.
Feb 11, 2014 | Polaris 2004 EDGE Touring 340
1999 grand marquis engine runs but car wont move
I am sorry but you have a failed automatic transmission. You will needit removed and rebuilt.
Oct 16, 2012 | 1999 Mercury Grand Marquis
Wont accelerate
check under the plastic where the air box snorkle sits. Sometimes the foam jams up under there and plugs off the air box. if not that check your air boots on the carb. they are famous for cracking and sucking in to much air.
Jun 08, 2012 | Polaris ATV
1999 passat v-6 abs,brake lite come on,oil lite beeps,no rpms. every thing runs fine. lasts about 10mins then every thing works fine. changed ign.switch,checked inst. cluster contections all looked good.
A friend of mine has a VW Sharan V6 that done almost the same things and it was the electric water pump on the front bottom right of the engine that seezed up( yours is most likely doing the same), it's a black cylindrical sausage shape but a little thicker in size.The water leeks into the motor when it seezes and causes a intermittent short circut.
Feb 02, 2010 | 1999 Volkswagen Passat
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
121 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
