Question about Vizio VP42-20A 42 in. Plasma TV
Red line screen lcd hdtv numberrf
Vp 42 vizio vertical red line on screen.How to fix that?
4 Suggested Answers
SOURCE: thin white static line at top of screen for some
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Posted on May 06, 2009
milkburp
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
budmrtn
  • 11361 Answers
SOURCE: My 42" Vizio LCD HDTV
It can be the unstable power supply due to bad DC filter caps, bad T-CON boards, main board.
I would inspect the power supply first for caps with domed tops.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 18, 2011
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
When i turn my vizio on is all it does is display vertical lines from top to bottom
mychaelmuch6
Go to menu.
press screen selection
just follow steps on how to clear or reset T.V.
Jul 23, 2012 | Vizio M420VT 42 in. LCD HDTV
Vertical red line through screen
This is a problem within the screen, probably the connection from the internal ribbon connector to the display. Unfortunatly the only way to repair this is to have the screen replaced.
Dec 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Hello there. My son hit my 47 in flat screen LCD
The screen is the most expensive part of the whole TV, save money for new set.
Dec 07, 2009 | Vizio GV42L 42 in. LCD Television
Black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Sep 28, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Thin white static line at top of screen for some channels vizio 42 lcd hdtv
Mar 13, 2009 | Vizio GV42L 42 in. LCD Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vizio VP42-20A 42 in. Plasma TV Logo
14 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
