Question about Frigidaire GSTF1670A Front Load Washer
Something rolling inside the Drum
Dear FixYa expert:
I have a Frigidaire Gallery Front loading clothes washer that I am repairing. At first I thought it would be an easy repair as I noticed one of the shocks that support the drum was cleanly broken. As I started to work on installing the new strut, I noticed a large piece of plastic sitting near the back of the washer. I removed the back and found a hole in the plastic "outer" drum that fit my discovered piece perfectly. TO check things out, I tried to rotate the drum manually and I can hear something rotating inside the drum between the steel drum and the plastic out drum. As I listened to the "rattle" it seemed to be coming from the center of the plastic drum. So here is my theory. The main bearings siezed in the middle of the spin cycle, caused the shock to break off (plastic part) and the steel drum hit the plastic outer drum and broke off a piece of it. What do you think? Now here are my questions.
#1) Where can I get an exploded view of this washer, Model FWTR647GHSO or "0' (zero, I can't tell which).
#2) How can I get in there to get that broken piece (or bearings) out from between the two drums?
#3) Do I have to take the entire drum out of the machine to do it?
#4) Regarding replacing the bearings (if that is the problem), how do you get the pulley off the back of the outer plastic drum in order to fix it?
What ever suggestions you might have would be appreciated.
  • 1,543 Answers
The rear half of the outer tub, with bearing is part # 131525500 and it looks like the back "spider" shaft is not available as a separate part from the inner drum. The "spider" shaft is most likely worn or damaged and in need of replacement also.
131618500
Then, there's that strut
134564200
Now, two pain in the back side hours of your labor and you've got your washer back, at more than what a new one would cost! Junk it and get a new larger capacity front loader.
Please don't rate this, as anything but the top rating will lower my score. I'm just giving you my honest opinion, that your machine is not economical to repair. I've owned a LG front loader for over 6 years and think they are the best, but there are other good front loaders out there also.
Posted on May 19, 2009
How do I level my frigdaire gallery front load washer
Thank you for your inquiry, friend!
In order to properly balance your Frigidaire washer you would need to seek the help of a professional. Regrettably, this is not a simple DIY job and I would highly recommend reaching out to an expert technician to ensure the repair is correct to prevent future issues. I hope this information helps to some degree. -Matt
Oct 11, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Fridgidaire gallery front load washer doesnt spin out and leaves clothes wet
sounds like the belt that goes around the drum has come off the pulley or belt has broken you should be able to look under it to see the belt is on or off. hope this helps you.
Dec 13, 2010 | Frigidaire GLTR1670A Front Load Washer
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Washer is putting holes in clothes
Check the inside of the drum when the machine is empty by feeling the entire surface with your hand. Take care as you are looking for something that's got stuck in one of the holes in the drum and is protruding into the drum, and this can often be a wire from an underwired bra!
If you find anything it should be removed by pulling it out carefull with a pair of pliers.
Mar 21, 2010 | Frigidaire ATF6000ES Front Load Washer
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
I have a frigidaire gallery front load washer need help
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
May 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Gallery front load washer Model # GL2F1240ASO
The solution to this problem was embarassingly simple. I had the spin cycle set on "Fast" as it seemed to stabilize the washer. Just for something to try, I switched it back to "Normal" and voila - no more brown stains. Haven't got a clue why.
Aug 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GSTF1670A Front Load Washer Logo
442 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
