Question about Refrigerators
My GE GDSS6KKXASS French Door refrigerator has frost/ice buildup on the back panel of the fridge, and it is especially bad around the holes in the panel. I can't tell where the water/moisture is coming from, and it frequently melts and pools in the bottom of the fridge, under the fruit & vegetable containers, so I have to soak it up every few weeks. The only thing that seems to help it so empty and defrost the entire fridge, but then in a few weeks the same problem starts again. Any ideas?
The door seal is leaking. The air that circulates thru the fridge is where the moisture is coming from. Since it has to run more often to keep it at the right temp, the ice forms on the back. Replace the seal and the ice will disappear.
Posted on Dec 31, 2013
  • 958 Answers
SOURCE: Evaporator coils frosting up
the frosting of the back compartment of the freezer indicates that the ice builds up at the evaporator ( the coil that cools). the system is supposed to melt the ice after a particular time interval for a period of time in order to start another cycle. im not sure if that model uses the electronic timer which you can not manually adjust to see if it is heating up on the heating mode. you would have to check three things. one is the defrost heater itself if it has continuity. another is the thing that we called thermodisc . its a part of the heating circuit where it cuts the heating current after it senses that the temperature of the evaporator is way up the thaw temperature. it is normally connected in series with the defrost heater and it is attached to the latter part of the evaporator tube. lastly which as i have told you is the timer. if its a mechanical timer, then probably it is not going to the heating mode. another is the electronic timer which is very hard to trouble shoot. you have to really observe the refrigerator how long it is running and if the compressor is stopping and the heater working by looking at the back if water is draining after a few minutes the compressor stop. as i may add, as you have said it is winter there, a thermostat setting could be an issue. the heater could probably not cope up with the coldness of the ambient temperature in which i may suggest to put the thermostat setting to the lowest setting on the knob. i hoped i was able to help....drcool
Posted on Feb 05, 2008
SOURCE: JCD2389DES Water Leak Problem
Once I saw that the drain tube went up over the coil before draining into the evaporator pan I decided to buy a small piece of flexible plastic tubing and re-route the tube so the water could freely flow down hill. It's been over two months with no additional problems. I can assume that since the water drains freely it doesn't stay trapped in the elbow freeze and the cause the collector tray to ultimately overflow.
Posted on Nov 24, 2008
freetek
  • 5568 Answers
SOURCE: Kitchen Aid bottom freezer has frost/ice buildup
Do you know for certain that the automatic defrost cycle is running at all?
Depending on the model, it should be entering the defrost mode every 12 or 24 hours. If the defrost timer is not easy to see (because of the drawer construction), you should be able to catch it by checking the walls of the freezer at random to see if they are still 'ice' cold or more temperate.
You may definitely have a leak, no argument there, but the defrost cycle may have been masking it while it was still happening by sending the ice/water down to the pan.
Posted on Jan 18, 2009
SOURCE: freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Posted on Dec 16, 2009
  • 5370 Answers
SOURCE: Water is pooling under vegetable/deli
Its a defrost problem.Click this link below and follow the troubleshooting:--- http://technoanswers.blogspot.com/2011/07/water-is-pooling-under-vegetabledeli.html ---------- This should help.Thanks.Helpmech.
Posted on Jul 08, 2011
How do I stop frost/ice from building up in freezer (bottom freezer of French Door Stainless Steel bought in Dec 2011)
Check the door gasket carefully for cracks or other leaks. It is crucial to have a good barrier between the moist room air and the super-dry air inside the box that will quickly suck in the ambient humidity and form frost.
It would be difficult to change the sensor and the heater, and if the defrost cycle is running (and you feel some warmth around the bottom of the box when it is cycling) then the sensor and heater assembly are working and do not need to be replaced. The best practice is to remove any frost buildup at regular intervals and often to prevent a thick buildup that is difficult to remove.
Nov 19, 2014 | Samsung RF26VAB (25.5 cu. ft.)...
GE Profile refrigerator Model # PFSF6PKXCWW motor is noticeably louder
if you are talking about the motor in the freezer the ice build up could be causing the fan to beat against the ice... could be a defrost cycle problem,,,, if ice is building up on rear freezer wall you have a defrost cycle problem and the ice is forminf around fan causing fan blades to hit the ice (loud noise)
Aug 28, 2014 | Refrigerators
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Cold on the top part but not cold on the bottom
Check the fins in the back of the "bottom" part for frost / ice buildup. It may be time to defrost your fridge.
Alternatively, if there is a lot of food crammed onto the top 2 shelves, it can prevent the air from circulating around the fins. Also check your door gaskets, especially if you have of frost / ice building up on the fins.
Jul 12, 2010 | Dometic RM2652 Refrigerator
Frost and Ice Buildup
If everything is cooling fine and the frost is not on the back wall but just the floor at the bottom then your defrost drain is stopped up. Remove the bottom basket and clean up the ice on the floor of the freezer. Look on the back wall and you will see some more ice up a littler higher at the back. This is where the drain is. Clean all the ice out from this area too using hot water or a hair dryer. Once you find the drain hole make sure you get all this ice out of it as well. You can take a screw driver once you have melted the ice and gently push it through the drain hole. Once the hole is cleared you should be able to pour hot water freely through the hole. (It is best to turn the refrigerator off while you do this)
Jul 01, 2010 | GE Profile PSS26NGS Side by Side...
I have LG French Door Refrigerator Model LFC25760SB. I have the ice build up problem on the floor of the freezer. Is there a way I can only turn off the Freezer so that it can thaw to resolve the problem?...
George,
The short answer to your question is no. It sounds like you are having the same problem I had almost 1 year ago. The defrost controller in your fridge has gone bad. I have an LFC25760 and had ice buildup in the bottom of the freezer such that water would start leaking onto the floor. The ice buildup in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain, which then causes the melted ice on subsequent defrost cycles to overflow the drip pan and flow into the bottom of the freezer and then eventually onto the floor when the bottom is full of ice. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Good-luck.
Jun 19, 2009 | LG LRFD25850 French Door Refrigerator
Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
