Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Working but making noise when spinning.
Hotpoint Aquarius Model WD61 Washer Dryer working normal but sometimes it is very noisey why?
    Sergeant:
  • 187 Answers
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion....
Posted on May 22, 2009
  • wajid Oct 10, 2012
    thanks for answer,i have checked every thing that you have suggested axcept coupling.pleasecan you tell me what are these.many thanks.wajid
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
I have an Aquarius WD61 washer/dryer. The door will not now open.
No date on this that I can find. Can you move the dial to a different setting? If so, just move it a fraction to see if it will engage. If it does engage, then you will need a new timer, goes under the dial. If it is a computer panel, try resetting it on another load setting and put it on the final spin.
Godd luck
Aug 08, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Hi i have a Hotpoint WD640 1400 spin Aquarius + and on the control panel it keeps flashing F-13 can anyone help
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Please rate my solution.
Thanks.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
236 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
