Question about Digital2 Pad Platinum 10 inch Tablet with 16GB Memory
Digital 2 pad frozen
Power button restarts the pad but it freezes at the digital2 screen
Kindle paperwhite keep freezing or won't let me swipe to change page
I always like to refer to Amazon help whenever possible. I copied their directions for this. Even if your's is not 5th gen it will work. You can also check specific info for your model by logging into Amazon.com Click help, then device help, click on you device and look through the info available.
Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation).
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart. Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
Dec 02, 2016 | Amazon Kindle Paperwhite
Digital2 tablet is fully charged and stays on "Digital2" screen
I would cycle the power before attempting any reset or factory reset.
Jan 03, 2015 | Digital2 7 inch Tablet with 4GB Memory
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My digital2 will not charge
It is probably the battery, try replacing it.
Dec 05, 2014 | Fisher New Tablet Pc Android 2.2 With...
My I pad is frozen, how do I get it unfrozen
Hold the button on the back edge near the back camera lense for about ten seconds.
Sep 22, 2014 | Apple iPad 2
I Pad is Frozen in a games app
Usually a reboot will fix this problem. Press and hold the power button (rectangular button on the side) until you get a "Slide to power off message". Then just slide the slider to power off and you will see a spinning wheel. When the spinning wheel disappears and the screen is totally black the you just need to restart the iPad by pressing and holding the power button until you see a silver Apple.
Jan 18, 2014 | Apple iPad (16 GB) WiFi Tablet PC
ASUS T100 stuck at preparing automatic repair message will.not reboot
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode...
Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Nov 19, 2013 | ASUS Tablets & eReaders
Frozen hold button
hold power button as long as it takes for the tablet to shut off then leave it alone for a few minutes.
Nov 10, 2013 | Hannspree HANNS pad SN10T1
Digital2 Pad Platinum 10 inch Tablet with 16GB Memory Logo
Top Digital2 Tablets & eReaders Experts
ka4iup
ka4iup
William Alequin
Gil Shultz
Are you a Digital2 Tablet and eReader Expert? Answer questions, earn points and help others
