Question about Spark Plugs BR4HS Plug 10/BX #3322
Nissan x-trail turn off engine while driving
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
It's electrical problem
Posted on Jan 05, 2014
Nissan X-Trail 2.2 Diesel 2001 White smoke coming from exhaust when driving not constant in intervals
White smoke usually indicates low compression pressures. Do a compression test to see if the rings are worn. Check oil consumption too. If the valve stem seals are worn then the engine will use oil too.
Sep 25, 2014 | 2005 Nissan X-Trail 2.0
Nissan x trail set time clock
It will be in the owners manual. No manual?........ look it up online under the year/make/model/radio in your search engine.
Aug 07, 2014 | Home
Nissan x-trail 1997
You have a problem with the antitheft system. Google "relearn key Nissan x-trail" and follow instructions. You may have to go to a dealer to get it done.
Jun 11, 2014 | Seasense EZ TROUBLE SHOOTER II CIRCU...
Nissan x-trail diesel code p0089
I would need to know what year model this is, engine capacity and engine code to confirm but generally on the x-trails that fault code refers to a mechanical fault on the fuel pressure regulator. This is for the YD22DDTi engine.
May 16, 2014 | Nissan Cars & Trucks
Nissan x-trail 2008
please go to this site for info, .aa1car.com/library/no_spark.htm. and click on first link. good-day!
Apr 11, 2014 | 2008 Nissan X-Trail
Nissan x Trail I have 2003 Nissan X Trail 2.2
check power steering pump valves as the noise could be valve vibration from weak control springs
timing chains do not rattle it properly adjusted and the so called rattle could be the injectors/ needles operating correctly
Apr 18, 2017 | Nissan Cars & Trucks
Fuel pump, problem???
If the engine does not speed up, is the throttle plate opening when you push on the gas pedal ?
If the fuel pump were at fault, the engine should stall.
Jun 30, 2013 | 2005 Nissan X-Trail 2.5i
Need the wiring diagram for a 2003 nissan x-trail engine?
what is A color of wire in nissan x trail cam position sensor 2003 model
May 28, 2012 | Cars & Trucks
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
26 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
