Question about Roland Boss BR1600CD Digital Recording Studio (with )
Br1600cd doesnt turn on
Turns on and immediately turns off
Powerpod 820 will not turn on. When connected to power, the lights flick on when the switch is on but immediately turn off. I cannot get the powerpod to power up. I have switched outlets, cords, and even...
There is a "Main L/R" button which most people have pressed to enable
the main speakers. Turn off the button. Then turn the unit on.
Then turn on the button again. Solved this issue for me.
Oct 13, 2011 | Music
When turned on, it blinks and everything stays lit. doesnt turn off either.
To turn it off you need to VERY quickly press the power button and get off it... If you hold the button it will stay on.
Sep 21, 2011 | Sabine Z1000 Zoid Clip On Tuner
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
I used the wrong power supply and now it won't power up at all. Had a look inside for fuses but looks like they are part of the circuit board??
you might of fried the circuit board. if you see fuses and they look burnt out you can try n replace em but my best surruestion is to calll roland and play dumb and tell them it just stopped working chances are its under warranty and youll get a new one.
Jun 20, 2011 | Roland Boss BR1600CD Digital Recording...
Whenever i push the the pedal down the distrotion comes on for 10 seconds and then turns off and the light doesnt turn on either help me!!!
If you are running on battery, replace the battery. The batteries tend to recover a bit and will operate the unit for a brief period
Mar 18, 2011 | Boss Mt 2 Metal Zone Effects Pedal
MPC2000XL MCD not working anymore..HELP PLEASE
If the unit uses a power adapter, check that the adapter is providing the correct voltage.
Feb 03, 2010 | Music
My 75 fender champ Hums loudly when I turn it on.
Check all the solder points on the capacitors in the power supply. I'm talking about the big can type caps. I've seen this problem on a lot of amps. Good Luck.
Jan 15, 2009 | Music
Roland Boss BR1600CD Digital Recording Studio (with ) Logo
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
