Question about Vizio GV52LF 52 in. LCD TV
52" VIZIO LCD backlit with no display
52" Vizio - Ihear I need to replace my LVDS....WHERE IS IT?!?!?
Is it big or small?
Is it visible when the back cover is removed?
is it integrated with the main board?
Is it under the main board?
Got a quick response from my first post that said replace the LVDS...got 9 people that voted yes!! Great - Im ready...even got a picture of it online and a place to buy it. I cant find it in my TV anywhere. Just a little nudge in the right direction before I remove every board and component in this TV would be great!
  • crewzen May 28, 2009
    Fixed!! Vizparts.com came through in a big way. They sent me the main board and power board. Only charged me for the main board with the expectation that one or the other board would be the culprit....not both. Also with the understanding that I would send the unused board and bad board back once resolved. Got some bad advice early on about the problem being the LVDS (lcd controller). Gal from vizparts.com said no way. She was right!!
    Got a Vizio that isnt working? go to www.vizparts.com and call them.
Hi Crewzen,
I have the same problem as you. You just didn't mention which was the culprit. I assume it was the mainboard, correct???
Thanks
Posted on Jul 25, 2010
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
How to replace lvds cable
The LVDS cable has a small tab on either side of the connector which gets pressed in so the connector can be slid out of its socket.
Feb 11, 2012 | Vizio VO47L 47 in. LCD TV
My Vizio HDTV has green/red snow on dark/white colors and it usually disappears but now it comes back for very long periods of time. I've done research and its come down to the LVDS cable. So, what are...
Usually if the LVDS cable between the main board and the T-CON board is bad, you will loose one of the three color signals, you may have thermal problem with the T-CON board. I would run the TV with the back open to see if it will take longer for the problem to appear, or get a can of freeze spray for electronic troubleshooting and cool down the T-CON board (board is under the metal shield that you will have to remove to get to all the cables, I would remove the shield and put the screws back in to keep the T-CON board in place).
The TV as shown in my album has bad T-CON board, the pictures get pixelated and scrambled after about 1/2 hour, I was using a small fan to keep it cool until I finally found a replacement T-CON board. Bad LVDS driver IC on the main board can also be the problem. Right now we need to find out if it is heat related problem or not.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 31, 2010 | Vizio L32 32 in. LCD HDTV
There is no picture or sound. Had TV for 2 years. checked all connections. tried to re-boot through vizio tech support. had no luck.
You either have a power supply issue or a main board issue. It's best to take it to a service center to have it diagnosed properly.
Jan 09, 2010 | Vizio GV52LF 52 in. LCD TV
Red lines across the screen and bleeding around corners
This is your LVDS cable. You could replace it yourself and find a replacement online.
1) flip the LCD screen down onto a soft blanket
2) remove all 30 - 40 screws on the back
3) pop the back off
4) look for the LVDS wire, it runs from the top of the LCD screen to under the power unit and into the Main Board.
Jan 05, 2010 | Vizio VW42LF 42 in. LCD HDTV
New Vizio 32" LCD TV loses color for several seconds when changing channels. Happens intermittenly
You will need to replace the LVDs cable. You do it yourself, if your a techie. There are a few websites that sell the cable. This is a known issue with the Vizio line. If you need more details on replacing it let us know.
Xe Technology
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
Big black bar in the middle of the screen vertical
You will need to replace the Main board and I would also replace the LVDS cable that connects the main board to the LCD panel. Very easy to do, but might take about 2 hours depending on your comfort level.
You will need:
Screw Driver
LVDS cable – Part # 0500-0505-0540
Main board – Part # 3632-0652-0395
Those part numbers will work if you have a model number VOJ320F1A.
If you post the model number I will try to find the part number for you.
thanks
Aug 11, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 47" Costco hdtv has red floating areas!
After posting this problem we did call Vizio. They sent out a repairman (had to wait over a week) who fixed it by: Replacing the LVDS cable and the main board. (Just like somebody on this blog wrote somewhere!) We also had just previously called our cable company who came out (also free) and checked our system only to find the cable running around the house to the tv needed replacing as it was sending zillions of errors. The red flowing problem (called "red pixilation") was due to the Vizio LVDS cable and main board being faulty from the factory.
Just want you out there in web land to know how to get your similar problem fixed!
Jun 10, 2009 | Vizio VO47L 47 in. LCD TV
VIZIO 52" LCD is on but....no display
If this is indeed an LCD and not a plasma, then you need to replace the LVDS (LCD controller) board.
May 18, 2009 | Vizio GV52LF 52 in. LCD TV
VIZIO 32 in HDTV color issues
CLEAN LVDS CABLE CONNECTOR THE END SIDE ATTACHED TO THE CONTROL BOARD, THIS IS THE BOARD WHO IS ATACHED TO THE LCD PANEL .
LCD PANELS FOR VIZIO ARE NOT AVAILABLE ,UNLESS THE TV IS COVERED UNDER WARRANTY ,IF THIS DOESNT HELP YOU HAVE TO REPLACE THE CONTROL PANEL BOARD, TRY EBAY TO GET THE BOARD .IF NEEDED
May 16, 2008 | Vizio L32 32 in. LCD HDTV
Vizio GV52LF 52 in. LCD TV Logo
329 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
