Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Washing machine leeking from underneath
My washer leeks big time when in use
  • 90 Answers
Check the door seal carefully. If no holes, then check the hoses and the waterpump.
Posted on May 20, 2009
My washer machine leaking water on fill or drain
Hi,you need to pull washing machine out and check filler pipe or pipes are not leeking,and take the lid and back off the machine and when it is leeking use a torch to see more cleerly.
Nov 05, 2016 | Washing Machines
I had the message sud on my washer I clean the filter at the bottom of the washer and replaced it and Now I have water pouring out everywhere
Seems like you have not got the filter plug in correctly, or it's not in tightly enough. Turn off the water, put a shallow tray underneath the filter housing, slowly unscrew the filter holder and drain out as much water as you can. Then fully remove the filter holder and check for damage or foreign matter in the screw threads. Clean it fully, dry and replace it. Turn on the water VERY SLOWLY and check for leeks.
May 16, 2015 | Washing Machines
Wher is it leaking
slide a piece of paper under the unit when the floor is dry, fill some water and peer underneath the unit, when you notice water drops this location will indicate your leek location, lay unit on its side and track down the leek
Jan 10, 2012 | Maytag Washing Machines
Slight leek on the front
In most cases, leaking is a sign of a clogged drain filter or drain pump. Water backs up and will find the point of least resistance. If you require further assistance, please post back with the make/model of your washer including if it's a top or front load machine.
Dec 29, 2011 | Washing Machines
Whirlpool washer is leeking? water comes out from underneath the washing machine. It was purchased 4 years ago?
it sounds like you have a leaking pump, or a hose has been split, or chewed through by vermin
Aug 18, 2009 | Whirlpool WTW6400SW Top Load Washer
My washer leeks water from bottom even when its not running and just sitting there. Seems after a wash the water hasn't totally drained out and then slowly starts leeking, actually alot of water is on the...
Have you checked the clamp on the drain hose? It may need tightening. All washers keep a small reserve of water in the bottom of the basket tank. If your drain hose hook is too high from the top of the washer, that much more water will be held below.
Aug 13, 2009 | Westinghouse Washing Machines
I just did a load of laundry at my mom's beach house. Second load so far is fine, however, first load seemed to leek from underneath. All water/drainage connections were dry. We moved and cleaned area and...
If all connections were dry, the water may have overflowed the top of the tub during a spin /rinse cycle. That could happen if there was a lot of water (i.e. set for large load) and a small amount of clothes.
Jul 08, 2009 | Washing Machines
Cabrio leeks when it drains
most probable cause it come from draining pump it has a water seal defective
Jun 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WD440 hotpoint washer dryer Leeks on spin from Tray
Hi , the electromagnetic water valve was leaking need to check or clean the devil contact gasket or either the vevil was rusted , the gasket cannot stop due to the surface of vevil was deteriorated.
check also the electromagnetic winding may open.
Feb 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
95 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
