Question about Toro Lawn Mower With Toro Power Tools
New trans now it goes fast but cannot pul backwards
I replaced the belt with a 33? auto belt. Installed a new transmission. When started it is in gear and goes very fast. Problem is it stays in gear and I cannot pull it backwards without raising front wheels. Is my belt to short? Thx jw
    Sniper:
  • 57 Answers
Probably. Always try to use manufacturer belts as they are designed and sized for the application. Length is not all that matters.
Posted on May 19, 2009
I got a troybilt rider mower. I dont know anything about mowers. I got this from a neglected owner and the final thing that got him to sell. Was the battery charger was wrong and it blew the acid all over ...
There should be a second belt that goes from the engine to the transmission. This could either be slipping due to a mis-adjusted pulley or another bad belt.
May 18, 2014 | Garden
2001 ford ranger 3.0 auto trans swap out with a 2002 auto trans
On Chevy transmissions there is, on the input shaft, there are two (2) little tabs at the 12 and 6 O'clock position or 180 degrees from one another. When installing the transmission these can often break leaving the transmission useless. It will need to be taken apart and checked on. If it is broken then you can easily replace it from a junkyard trans. (just look forward to a day in the yard tearing apart a transmission) and replace it accordingly.
Keep in mind when reinstaling the replaced transmission, that you HAVE to line these up by spinning the Torque Converter untill it slips on easily. otherwise it will just break again.
Feb 24, 2014 | 2007 GMC Sierra 1500
Auto trans slips at 33 mph
I would have a trans service somtimes its just a clean up that needs done
Aug 27, 2012 | 1993 Subaru Impreza
1995 Toyota Tercel SLUGISH
I believe that what you are experiencing is whats called FAILSAFE MODE, which means its stuck in 2nd or 3rd gear due to recent change in driving habits.... maybe you got on the accelerator a little too rapidly or sharp corner too fast.... All, Nissan's, Toyo's, and most cars have this mode wich is meant to prevent further damage to the trans. This may not be what your experiencing but it sounds like the symptoms, sluggish, slow acceleration,.......
have you experiencs and shifting issues, is it an auto or manual trans? if you have a trans power or over drive button and or light on dash or shifter for automatic, observe when you start it up next time and you may find it blinks 8-10-12 times.... if so you have damaged the trans due to mismatched/mixed tire sizes and or tread depth, and brans or tread styles.... yes it doesn't just ruin 4x4 auto trans,.... it kills any transmission after unknowingly driving around with incorrect tires. I work for Nissan and have for 26 years and i have seen chain tire dealers like Walmart, Sears Roebuck, Midas, Tire Wharehouse, Pepboys, and dozens of others cause the transmission planetary-gear failure; in mostly automatic 4x4 or AWD vehicles when replacing just one two or three tires AND NOT THE COMPLETE SET AS REQUIRED BY EVERY AWD AND 4X4 AUTO MANUFACTURER. DON'T BE A VICTIM... BE A WISE CONSUMER.... AND GET AN ATTORNEY IF YOU BECAME ONE ALREADY....
THANKS AND GOODLUCK
TransNissPro
Jun 17, 2012 | 1995 Toyota Tercel
Mower will not move foward or backwards belt ok and turning fan and pully.
then the hydrostatic transmission is shot, look around for a new one or a used one. good luck as a new transmission will cost as much as another mower.
Apr 14, 2011 | Husqvarna Yard Tractor
The fluid from my transmission is mixing with radiator fluid. I was told that the core is burnt out in my radiator, and all that was needed to be done is to replace the old radiator with a new one and...
Hello
What happened is the tube that goes thru the radiator sprung a leak and coolant is getting in the trans and visa-vera so the answer that you got is 100% correct. But you have to change trans fluid and coolant and do NOT drive or you will be buying a new trans. Thanks
Jan 16, 2011 | 1984 GMC S-15 Jimmy
I have an old Pioneer stereo auto turntable PL-5.It is rarely used and worked fine until my grandson started to turn the turntable by hand and I think backwards.Now it speeds up and races.Can this be fixed...
if the speed is constantly fast the drive belt may have ridden up on the top part of the motor pulley.inspect and refit.if the speed varies check operation of 33/45 switch.
Dec 15, 2009 | Pioneer Audio Players & Recorders
92 prelude si (auto)
With normal acceleration the 1st to second shift point should be around 2500-3000 rpm. Most of your shifts under moderate acceleration will take place at this same point or when there a light load on the transmission. Under hard acceleration the RPMs will climp higher due to increased power needs and the computer will shift when less power is needed or the RPMs climb to an unsafe speed say5000-6000rpms (depending on where yours redlines). Also going up a steep hill will raise the RPMs higher and goind down a hill will cause a faster shift at lower RPMs. These can always be altered by an individual owner by adjusting shift points, using performance parts and if you have problems (low tranny fluid/trans issues). Your trans RPMS are fine and will vary depening on how your foot accelerates. The shift pattern should be the same every time you drive slow/medium/fast/, look for changes in those patterns you will also catch a problem early.
Jun 14, 2009 | 1992 Honda Prelude
Toro Lawn Mower With Toro Power Tools Logo
136 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
