Question about Bemis Humidifiers
Bemis water wheel manual
Looking for a manual
The light is on but the motor doesn't start up even with the moisture set high
Please check the switch for the water bucket that senses wether the container is in place or not. That will stop the unit from running.
Dec 05, 2010 | Bemis 4D7-800 Humidifier
My unit has a new filter, all parts seem to be in place, it has filled with water. It does not turn on no matter how high I turn the humidistat.
is the water fill rod in place with float attached, and the opposit end in the switch hole? does the humidistat clik on and off when turned (just clik) put your finger or a pencil in the hole on the underside and try again. its prolly the float poor design...
Oct 28, 2010 | Bemis H12 300 Humidifier
Fill level & digital readout (bemis humidifier)
There is a sticker that comes in the owner's manual that apparently falls out frequently. I was told that the fill level is two inches below the top edge of the reservoir. I am going to mark mine with a Sharpie since stickers have a tendency to fall of when wet.
Jan 05, 2009 | Bemis Whole House Digital Humidifier ED11...
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Water Wheel won't keep turning
This humifier has a black drive wheel and a white idler wheel. On mine, the idler wheel froze up which caused the drive wheel to damage itself trying to turn the drum. First, free up the idler wheel and replace the shaft it rotates on. The idler wheel is still available but you'll have to fabricate the shaft using a machine screw and hollow shaft from your local hardware store. When the idler wheel turns freely, the drive wheel (if still in decent shape) can do its job of turning the drum. If not, you can replace the drive wheel (also still available). I recently put a small rubber band in the groove of the drive wheel and it enabled it to get the necessary grip on the drum.
It's getting harder and harder to keep these wonderful Bemis water Wheel humidifiers alive as the years go by. I wish they still made them because no other humidifier comes close.
Rick
Dec 18, 2008 | Bemis 4D7-800 Humidifier
Could you direct me to instructions on disassembling the Bemis 500 humidifier so I can clean it, specifically the fan?
I found your web site to be an essentially useless waste of my time, and was not surprised at all when you offered to sell me something, rather than addressing the problem.
Please stay out of my mailbox; Bemis is on my list of "Do Not Buy" products. Maybe others are as bad, but at least I can give them a try. I already know you guys are are useless sales pitch.
Dec 12, 2008 | Bemis Cool Mist 336 500 Humidifier
Moisture not coming out
i realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Jan 20, 2008 | Bemis Whole House Digital Humidifier ED11...
Bemis Water Wick 6974Tanks will not disperse water properly
sounds like new caps should solve it, but have you tried soaking the old caps in vinegar overnight? these guys are not the only ones, but they have the correct caps in stock at a pretty good price http://www.marbeck.com/humidifier_parts_bemis.html hope this helps :)
Mar 14, 2007 | Bemis 697 400 Humidifier
Humidifiers Logo
Top Bemis Humidifiers Experts
Mack Baxter
Dennis
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
