I am having problem with my ricoh 2015 copier . it is a new machine just 500 copies are made on it, but when ever i start it shows service call 901. plzz tell me the solution
It is asking you to install your mechanical counter,which you plug into a socket located on the outside of the copier. If you do not have this option then check fuse labeled #6 on your power supply.
Our 350 appears to bog down when making multiple copies. Almost like a memory issues or needs to...
(More)
Our 350 appears to bog down when making multiple copies. Almost like a memory issues or needs to "reboot". Our old copy repair guy had a way to clear this, running through a sequence of buttons (he is no longer in the area). The new copy person does not seem to have an answer. Any help?
