Question about John Deere 650 750 850 655 755 855 955 670 770 870 970 Attachment Tech Manual
Fuel guage problems
Replaced level sensor in tank and guage on dash,guage reads full no matter how much fuel or even if level sensor is wired!
    Sergeant:
  • 384 Answers
Check float in tank 4 movement shake tank u should hear it move . if u hear it check wires
Posted on Jan 01, 2014
Gas guage reads full all the time
More than likely the fuel tank level sensor (which is located inside of the fuel tank is seized. You will have to have the fuel pump and level sensor replaced.
Jan 05, 2015 | 2001 Buick LeSabre
2009 ford escape read empty after refueling to full tank
Sounds like it's the fuel level sensor in the tank that measures that for the dashboard. It's either that or it's a different issue. Could even be a fuse or relay that's bad. Check your fuses first, just in case.
Sep 12, 2014 | 2009 Ford Escape
My 2006 ford explorer displays low fuel level n the fuel gauge does nt move or work even when there is full tank of fuel
make sure the sender is grounded or your guage wont work at all..there should be a ground wire .. if not add one someplace..
Dec 26, 2013 | Ford Cars & Trucks
Fuel guage reading was erratic. Replaced fuel pump and sensor..fuel guage then read a constant 1/4 tank lower than it actually was. Mechanic checked and said it was wired wrong...fuel guage then read...
Thanks for choosing FixYa and welcome. You may have a bad sending unit. It could also be a defective dash voltage regulator, lost ground at sending unit, break in the wire at the dash harness too. It can be anyone of these to be honest.
May 05, 2011 | 2001 Isuzu Rodeo
Fuel gauge is on empty and the low fuel light is on, but the tank is full
u either have a bad level sensor in the tank or the guage is bad. u need to get wiring diagram and find connector for fuel sending unit and jump wires to trick guage into thinking it is full if it still say empty u need instrument cluster if it goes to full it level sensor in the tank
Feb 23, 2011 | 2002 Saturn VUE
Fuel gauge is not reading at all even though there is fuel in gas tank?
check first the guage indicator,,,if its good,,, full down the fuel tank and check the fuel gauage sending unit(fuel level sensor) is attached to the to the fuel pump control module..
Jun 28, 2010 | 1998 Jeep Cherokee
The fuel gauge is'nt working.I tryed to ground it
When testing a fuel guage you should disconnect the wires to it,guage should read over full,ground the float wire,turn off key then turn back on should read empty.You have to cycle the key for guage to move.If still inop the wire is broken in the harness between the tank and the dash.Voltage on the float wire is low.When tested with a test light it will barely light the light and pulsate.This test indicates the wiring is good.
Apr 17, 2010 | 1991 Chevrolet C1500
Gas Gauge not reading correctly
The most likely culprit is the sending unit in the tank. They are relatively easy to change, as long as you don't have much fuel in the tank. It's a mechanical unit that has a float that raises and lowers with the fuel level, however with age, the floats can develop leaks and no longer float, of the electronic portion of the unit can go bad and not register the proper level. They are replaced and an entire unit, so it doesn't matter which happened, you will need to change the fuel tank sending unit.
Jan 11, 2009 | 2004 Ford Explorer
Fuel guage reads 1/4 at all times even when full. How do I repair
1.If the needle on the guage is stuck. you can try tapping the guage to see if the needle moves or turn the ignition on and off a few times to see if you can get it to move. If the guage drops to empty when you turn off the ignition you know that its not the guage. (note that the guage does not drop to zero when ignition is off with all cars of this age).
2. The problem could be with the sensor in the fuel tank itself. Rocking the vehicle up and down from the rear (you will need help doing this) may free the sensor level indicator ball in the tank.
Dec 17, 2008 | 1983 Jeep CJ7
2006 trailblazer
Ajkill is right. I had the same problem with the fuel light always being on and the guage read empty no matter how much fuel is in the tank. I had to have the fuel level sensor in the tank replaced. This is something that they have to drop the tank for. It was about $400 with the part and labor at the dealership.
Jun 05, 2008 | 2006 Chevrolet Trailblazer
John Deere 650 750 850 655 755 855 955 670 770 870 970 Attachment Tech Manual Logo
98 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
