Question about Cuisinart GR-4N Indoor Grill
Flashing green indicator lights
This is only the second time using this product with in 24 hours from each use. I started it up, waited for it to warm up and I got nothing. All I got is both the griddle and the grill/panini indicator lights flashing green.I have looked through the entire manual and indicate absolutely nothing wrong with the product. Can you please tell me if there is a solution to this issue?
    Habit-Forming:
  • 188 Answers
When the green light is flashing, it is not at the set temperature. It will be solid when temperature is correct. You are selecting grill or griddle and then turning the temperature knob for that selection? It's not working with either selected?
Posted on Dec 31, 2013
2 Suggested Answers
kebah
  • 683 Answers
SOURCE: Lost my instruction manaual. Could you email me
You can download grill manuals at http://www.cuisinart.com/share/pdf/manuals/gr-55.pdf.
Posted on Jun 01, 2011
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
There is also a way of setting it by simply turning the light on and off at the desired time. Can yu help?
Manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The manual says:
"To automatically program, letting the switch
timer "record" your ON/OFF activities over a 24-hour period,
storing them as programmed settings:
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Press the dial as an ON/OFF switch to turn lights ON and OFF
at the ON and OFF times you desire for the first 24 hours.
At the end of the 24-hour period, the switch timer will be programmed
and the Red indicator light will stay ON, indicating
that the switch timer is in AUTOMATIC mode."
Sep 17, 2010 | Intermatic Programmable 24 Wall Switch...
Power on Board 450 portable charger light - green flashing
What your seeing there is indicating fully charged.
Apr 01, 2010 | JUMP START SYSTEM
Gaggia Syncrony won't heat up.
I switch the machine on and the green light (number 24) flashes to indicate it is warming up but it never gets there it just keeps flashing for at least half an hour.
Dec 31, 2009 | Gaggia Syncrony Logic 74884 Espresso...
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
Sep 29, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Cuisinart GR-4N Indoor Grill Logo
147 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
