Tablets & eReaders Logo
A
Anonymous Posted on Dec 31, 2013
Cant save my apps to my extarnal sd card - Proscan Tablets & eReaders
1 Related Answer
cinek79
IT aid
  • 320 Answers
  • Posted on Apr 01, 2014
SOURCE: Im using a tablet and I cant move apps and games
Hi if you want move apps to sd card go to settings, application and there press on the app which you want move. On the next screen you will see details about the app and a button move to sd card, just press it and the app gonna be moved to sd card. Bear in mind that some of the application can't be moved you will see then grey button.
How do I move apps to SD card
apps cant be stored on an SD drive
I have hipstreet pulse tablet how do I get y apps to go onto my micro sdcard
You don't. Most apps will not load onto an SD card. This is because that many SD cards are not fast enough to support the app's needs, and also the app writers don't go to the trouble of writing apps to be loaded on SD since not every tablet has one. SD cards are primarily for the use of storage of photos, music, and videos. A few apps CAN, if designated, store some data and cache info on the SD, but your issue should be with the tablet makers for not putting enough memory in the tablet itself in the first place. This is how they save money.
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
1helpful
Have. Gigaset qv830. I've put in an sd card. When I download book to kindle app how can I save to sd card and not on tablet?
Go into "storage" in settings and then scroll down to the Kindle app. Select "move to SD card"
How to save downloaded apps to an external SD card?
open up file explorer first. than copy the files and paste them onto your sd card
I cant download any apps says insufficient storage but have an sd card that's empty
You can try moving some of the apps to the SD card. If an app cannot be moved, you will get a warning message. Also, if you have any videos, songs or photos on the tablet move them from the internal storage to the SD card.
1helpful
Im using a tablet and I cant move apps and games to SD card
Saving pictures to sd card
Click on the "Apps" button and then "My Files". This should launch the files manager.. Be careful but once you find it and select it (a green check-mark will appear in the box) the "Move" button will appear in the upper right between "Copy" and "Delelte".
Transfer data from galaxy 10.1 note to sd ext storeage
Go to the play store and download a file management app. Use the app to move the files. OR, connect to a PC and manually move the files to the SD card
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
