Question about GE Spacemaker JMP28 Electric Kitchen Range
The oven runs too hot...even at lower temps
It burns everyting
  • 26 Answers
If the oven is in temp runaway and just gets hotter and hotter, always on, then there is a failed component. If the temp is just somewhat hotter but is still being controlled then there is a user temp offset procedure to calibrate the oven temp. See your user manual. If a failed component it can be several things from a oven temp probe to the oven controller. There are electrical checks to determine which including reading the resistance of the temp probe at a known oven temp and checking this with a oven probe temp vs resistance chart.
Posted on Jan 02, 2014
Oven is too hot. How do I adjust the temp.
Something has to be wrong with the thermostat that controls internal temps. Replace it
Nov 18, 2015 | Kitchen Ranges
Food in microwave is burning on edge and cold in the center
you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
Dec 29, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
Lower range will not come up to temp on 'bake' after 2 hours it only got up to 275 o but it got to 450 in 15 minutes on broil. This is a sudden thing as it was fine last night.
either the bake element in the lower oven has what is called a "hot-spot" a discolored area on the element and can no longer pass enough current to heat the oven and will most likely burn out soon,or a thermocouple went bad that senses oven temps,but this bulb in the roof of the oven normally goes bad over a matter of time
Feb 12, 2011 | Maytag MER6872 Gemini Electric Kitchen...
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Oven is burning food and seems too hot
HI. the oven temp sensor is malfunctioning. have it inspected for damage. check the wires leading from the control to the sensor for cuts and damage as well. replace the sensor if these issues with heating persist.
Sep 20, 2009 | Ovens
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Oven shows temperautre but does not get very hot
most likley you have a burned out elements, the tempature is probably just the temp you are selcting, if I am incorrect in the temp, ie, it does show the temp as oven heats, then the most likley problem is the tempature sensor is faulty or wiring to the sensor is faulty.
Apr 10, 2009 | Ovens
Wall oven too hot,at 350 setting is almost 400 degrees burns food
I have a very old GE wall mount oven. Original to around 1960. You can take the temp control knob off and there is an adjustment on the back of it. Easy peasy and only need a screwdriver.
Dec 05, 2008 | Frigidaire Kitchen Ranges
Burning hot oven door
As far as I'm concerned this is a safety hazard and not acceptable be any means. No oven face should reach temperatures that can cause serious harm to the consumer. For some reason the door is not releasing the hot air built up between the glass sheets. When the oven is running, can you feel hot air escaping through the top of the door ? Also, is there hot air coming out at the sides of the door ?
Jan 21, 2008 | Whirlpool GBD307PDS Electric Double Oven
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
GE Spacemaker JMP28 Electric Kitchen Range Logo
125 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
