Question about Boating
Idles down whenjohnson outboard motor - Boating
  • Fabrice Wolters Dec 31, 2013
    Hi Devin Templeton, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    What kind of Johnson do you have? How many horsepower and year? What happens exactly?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
Find carburetta that has connection to thottle control handle or remote box , i dont know how meany carbs you have but on multi carbs there is one that is main controler for linkage ! on that carb it will have a screw that holds the tickover , adjust this so you have 800 rpm and then test in lake and select forward and see if enough !
Posted on Jan 18, 2014
40hp mariner sluggish
compressions more than 100psi ? carb clean and fuel not older than 5mths ? timing correct ? running on all cylinders ?
Mar 06, 2012 | Light Outboard Motor Boat Bass Fishing...
How do you set the idle on an evinrude motor
The motor end of the control cable has an adjustment on it where it is clamped down to the cowl. Loosen the clamp nut and screw the cable end in or out to get your desired idle speed.
Aug 20, 2010 | Light Outboard Motor Boat Bass Fishing...
93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
Jun 29, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
Motor kills when put into gear
u have no spark in #2 cyl check for spark with plug if its week regap it
Feb 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
51 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
